メインコンテンツにスキップ
HP ZBook 15 Screen Replacement
必要な工具と部品
  1. HP ZBook 15 Screen Replacement, Battery: 手順 1、 2の画像 1 HP ZBook 15 Screen Replacement, Battery: 手順 1、 2の画像 2
    • Flip the laptop over.
    • Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Remove the battery from the laptop.
  2. HP ZBook 15 Screen Replacement, Screen: 手順 2、 1の画像 1
    • Orient the laptop keyboard-side up.
    • Use tweezers to remove the adhesive covers for the screws.
  3. HP ZBook 15 Screen Replacement: 手順 3、 1の画像 1
    • Remove the two 6mm screws with a Phillips #0 screwdriver.
  4. HP ZBook 15 Screen Replacement: 手順 4、 2の画像 1 HP ZBook 15 Screen Replacement: 手順 4、 2の画像 2
    • Pull the bezel away from the screen.
    • Be sure to go one edge at a time! Do not pull hard on the corners as it may crack the bezel.
  5. HP ZBook 15 Screen Replacement: 手順 5、 1の画像 1
    • Remove the four 3mm screws with a Phillips #0 screwdriver near the corners of the screen to remove the display.
    • Be careful not to confuse any screws. They are close together and you may remove the back cover instead of the display.
  6. HP ZBook 15 Screen Replacement: 手順 6、 2の画像 1 HP ZBook 15 Screen Replacement: 手順 6、 2の画像 2
    • Do not peel the tape from the side closest to the bottom of the screen panel! This may rip out the connector's wires.
    • Gently lower the screen and lay it face down on the keyboard.
    • Lift the corners of the tape closest to the top of the screen and peel toward the center carefully.
    • Slowly pull the tape away from the sides.
    • Lift the tape and disconnect the screen connector.
    • You can leave the tape stuck to the cable connector and still be able to remove it.
終わりに
8 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Grant Terris
メンバー登録日: 01/30/15
2,795 ポイント
12のガイドは作成済み
チーム
Cal Poly, Team 8-43, Amido Winter 2015 Cal Poly, Team 8-43, Amido Winter 2015人のメンバー
CPSU-AMIDO-W15S8G43
4 メンバー
15のガイドは作成済み
3 件のコメント
Worked great! Only caution that I would add is that on one of the machines I took apart, the adhesive strip behind the bottom of the bezel stuck to the bezel and not the circuit board behind. I had to carefully slide my finger between the adhesive strip and the bezel to separate them. Once the bezel was removed, I was able to stick the adhesive back down. I think this laptop may have been exposed to some sort of liquid, so this may not be a common issue.
dwakefield - 返信
My ZBook 15u g5 does not have any adhesive covers around the screen. How do I replace?
H B - 返信
Hello can i replace my hd screen with another fhd one?
Mohand Almohands - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 19
過去 30 日: 97
今までの合計 15,485
