メインコンテンツにスキップ
HP ZBook 15 Optical Drive Replacement
必要な工具と部品
  1. HP ZBook 15 Optical Drive Replacement, Battery: 手順 1、 2の画像 1 HP ZBook 15 Optical Drive Replacement, Battery: 手順 1、 2の画像 2
    • Flip the laptop over.
    • Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Remove the battery from the laptop.
  2. HP ZBook 15 Optical Drive Replacement, Back Cover: 手順 2、 1の画像 1
    • Slide the right lever firmly to the right.
    • Slide the cover towards yourself to remove it.
  3. HP ZBook 15 Optical Drive Replacement, Optical Drive: 手順 3、 1の画像 1
    • Unscrew the captive screw shown near the battery compartment with a Phillips #0 screwdriver.
    • The screw does not come out all the way and stays attached to the computer.
  4. HP ZBook 15 Optical Drive Replacement: 手順 4、 3の画像 1 HP ZBook 15 Optical Drive Replacement: 手順 4、 3の画像 2 HP ZBook 15 Optical Drive Replacement: 手順 4、 3の画像 3
    • Push outward on the metal optical drive tab with a metal spudger to unlock the drive from its position in the case.
    • Once the drive is protruding from the side of the computer, pull it the rest of the way out.
終わりに
4 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Grant Terris
メンバー登録日: 01/30/15
2,795 ポイント
12のガイドは作成済み
チーム
Cal Poly, Team 8-43, Amido Winter 2015 Cal Poly, Team 8-43, Amido Winter 2015人のメンバー
CPSU-AMIDO-W15S8G43
4 メンバー
15のガイドは作成済み
2 件のコメント
Mine won't come out and now I think my silver tab is bent. Please help me!
Sajid - 返信
Oddly enough, mine came with no DVD drive but a blanking… thing, which seems to be a trimmed-down version of this official adapter (HP SPS 734298-001) without the electronics. I bought a cheap chinese ODD caddy, tore it down and salvaged the logic board. Luckily, I got everything lined up after a few adjustments (the chinese logic board is a bit longer than the HP one).
Now I’m rocking an extra drive bay without paying the $75 some shops ask for the official one.
I use it as swappable storage (not hot-swappable, mind you) . Very handy for doing drive imaging and cloning when working as an IT technician out in the field.
Luis Alejandro Araúz - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 30
今までの合計 6,461
