メインコンテンツにスキップ
HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement
必要な工具と部品
  1. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Batteries: 手順 1、 3の画像 1 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Batteries: 手順 1、 3の画像 2 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Batteries: 手順 1、 3の画像 3
    • Slide the rear compartment cover in the direction of the arrow.
    • If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
  2. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Shell: 手順 2、 2の画像 1 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Shell: 手順 2、 2の画像 2
    • Remove the four 4mm screws using a Phillips #00 screwdriver.
  3. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: 手順 3、 3の画像 1 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: 手順 3、 3の画像 2 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: 手順 3、 3の画像 3
    • Grip the main body and pull the joystick outwards until the entire front panel pops off.
    • Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
  4. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: 手順 4、 2の画像 1 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: 手順 4、 2の画像 2
    • Use a spudger to pry apart the two halves of the assembly.
    • Work slowly, prying a small section at a time until the halves are completely separated.
  5. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Trigger: 手順 5、 3の画像 1 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Trigger: 手順 5、 3の画像 2 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Trigger: 手順 5、 3の画像 3
    • Grasp the trigger with one hand while pushing against the outer wall of the shell.
    • Apply pressure, pulling the wall away from the trigger.
    • Remove the trigger starting from the freed edge.
    • The spring-rod assembly can easily come apart. Inserting the large end first during reassembly may make the process easier.
終わりに
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Clement Cheung
メンバー登録日: 01/24/19
643 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team S18-G5, White Winter 2019 Cal Poly, Team S18-G5, White Winter 2019人のメンバー
CPSU-WHITE-W19S18G5
2 メンバー
14のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 16
今までの合計 1,775
