メインコンテンツにスキップ
HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement
必要な工具と部品
  1. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Batteries: 手順 1、 3の画像 1 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Batteries: 手順 1、 3の画像 2 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Batteries: 手順 1、 3の画像 3
    • Slide the rear compartment cover in the direction of the arrow.
    • If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
  2. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Shell: 手順 2、 2の画像 1 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Shell: 手順 2、 2の画像 2
    • Remove the four 4mm screws using a Phillips #00 screwdriver.
  3. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: 手順 3、 3の画像 1 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: 手順 3、 3の画像 2 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: 手順 3、 3の画像 3
    • Grip the main body and pull the joystick outwards until the entire front panel pops off.
    • Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
  4. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: 手順 4、 2の画像 1 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: 手順 4、 2の画像 2
    • Use a spudger to pry apart the two halves of the assembly.
    • Work slowly, prying a small section at a time until the halves are completely separated.
  5. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Small Circuit Board: 手順 5、 2の画像 1 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Small Circuit Board: 手順 5、 2の画像 2
    • Using a Phillips #00 screwdriver, remove the four 4mm screws located on the joystick circuit board underneath the top half of the controller.
  6. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: 手順 6、 3の画像 1 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: 手順 6、 3の画像 2 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: 手順 6、 3の画像 3
    • Remove the orange flat cable by pulling the orange tab parallel to the circuit board.
    • Release the blue flat cable by lifting up the white latch with a spudger.
  7. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Main Circuit Board: 手順 7、 3の画像 1 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Main Circuit Board: 手順 7、 3の画像 2 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Main Circuit Board: 手順 7、 3の画像 3
    • Remove the two 6mm screws at the base of the ring using a Phillips #0 screwdriver.
    • Pull towards the base of the controller to release the black wire from the connector on the circuit board.
    • Pull the ring apart from the rest of the controller.
  8. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: 手順 8、 3の画像 1 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: 手順 8、 3の画像 2 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: 手順 8、 3の画像 3
    • Remove the two 3mm screws on the V-clip using a Phillips #00 screwdriver.
    • Remove the V-clip from the device.
  9. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: 手順 9、 3の画像 1 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: 手順 9、 3の画像 2 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: 手順 9、 3の画像 3
    • With the V-clip off of the controller, use a Phillips #00 screwdriver to remove the remaining 4mm screw.
    • Remove the circuit board.
終わりに
4 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Eeshan Mishra
メンバー登録日: 01/24/19
424 ポイント
4のガイドは作成済み
1件のガイドコメント
Awesome! But were do you get the components to replace from??
Since separate controllers are very difficult to find and expensive (You wont find Samsung ones) I will be interested to buy a few to do repairs to friends and so.
Baba Nam Kevalam - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 21
今までの合計 2,202
