メインコンテンツにスキップ
HP TouchPad Microphone Replacement
必要な工具と部品
  1. HP TouchPad Microphone Replacement, Front Panel Assembly: 手順 1、 1の画像 1
    • In the following steps, you will use a metal spudger to lift the front panel out from the rear case of your TouchPad.
    • The front panel is held in by seven clips (boxed in red) that are lightly anchored to the rear case. When you remove the front panel assembly, you are bound to break either the clips or their supports attached to the rear case. We will update this guide as we find replacement parts or a better method to remove the panel.
    • As you remove the front panel assembly, also be careful not to damage the ambient light sensor (boxed in yellow) or the two antennas (boxed in orange).
  2. HP TouchPad Microphone Replacement: 手順 2、 1の画像 1
    • Insert a flat metal spudger in the gap between the rubber outer ring on the front panel assembly and the black plastic rear case near the USB connector.
    • Pry the front panel assembly up from the rear case, being careful not to damage the LCD or the glass panel.
    • As you work through the following steps, insert your metal spudger and pry the front panel up, but do not try to slide the spudger along the gap you're creating. Always remove your spudger, then insert it at another spot and pry upward.
  3. HP TouchPad Microphone Replacement: 手順 3、 2の画像 1 HP TouchPad Microphone Replacement: 手順 3、 2の画像 2
    • As in the previous step, use a spudger to pry the front panel up from the rear case along its long edge on the volume button side of the TouchPad.
    • Continue to pry the front panel assembly up along the volume button side of the TouchPad until there is a gap between it and the rear case.
  4. HP TouchPad Microphone Replacement: 手順 4、 2の画像 1 HP TouchPad Microphone Replacement: 手順 4、 2の画像 2
    • Pry up the front panel assembly along the top edge of the TouchPad.
    • Be careful not to damage the ambient light sensor or the upper antenna.
  5. HP TouchPad Microphone Replacement: 手順 5、 1の画像 1
    • Pry up the front panel along the edge closest to the home screen button.
  6. HP TouchPad Microphone Replacement: 手順 6、 2の画像 1 HP TouchPad Microphone Replacement: 手順 6、 2の画像 2
    • Before lifting the free side of the front panel up from the rear case, you may need to release it from the plastic retaining clips holding it down.
    • Use your metal spudger to pull the stuck retaining clips away from the edge of the front panel.
  7. HP TouchPad Microphone Replacement: 手順 7、 1の画像 1
    • After freeing the retaining clips, lift the front panel assembly away from the rear case.
    • Do not try to remove the front panel assembly from the TouchPad just yet, as it is still connected to the motherboard.
  8. HP TouchPad Microphone Replacement: 手順 8、 1の画像 1
    • Use the attached black tab to pull the display data cable straight up and out of its socket on the motherboard.
    • Pull the cable upwards and not parallel to the face of the motherboard. Doing otherwise may damage the socket on the motherboard.
    • Take care not to pull on the ribbon that is stuck by adhesive to the bottom of cable you are detaching. It does not need to be disconnected.
  9. HP TouchPad Microphone Replacement: 手順 9、 3の画像 1 HP TouchPad Microphone Replacement: 手順 9、 3の画像 2 HP TouchPad Microphone Replacement: 手順 9、 3の画像 3
    • Use your fingernail to carefully flip up the retaining flaps on the two digitizer ribbon cable ZIF sockets.
    • Be sure you are prying up on the hinged retaining flaps, not the sockets themselves.
    • Pull the digitizer ribbon cable straight out of its two sockets on the motherboard.
  10. HP TouchPad Microphone Replacement: 手順 10、 1の画像 1
    • Remove the front panel assembly from the rear case assembly.
  11. HP TouchPad Microphone Replacement, Microphone: 手順 11、 2の画像 1 HP TouchPad Microphone Replacement, Microphone: 手順 11、 2の画像 2
    この手順で使用する道具:
    • Use the edge of a plastic opening tool to flip up the microphone ribbon cable retaining flap.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Use a pair of tweezers to pull the microphone cable out of its socket.
  12. HP TouchPad Microphone Replacement: 手順 12、 2の画像 1 HP TouchPad Microphone Replacement: 手順 12、 2の画像 2
    • Use your tweezers to remove the black rubber grommet between the microphone and rear case.
  13. HP TouchPad Microphone Replacement: 手順 13、 1の画像 1
    • Use the edge of a plastic opening tool to pry the microphone away from the portion of the rear case right above the camera.
  14. HP TouchPad Microphone Replacement: 手順 14、 1の画像 1
    • Remove the microphone.
終わりに
作成者
2人の作成者と共同で作成されました。
Andrew Bookholt
596,157 ポイント
619のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 13
今までの合計 7,560
