メインコンテンツにスキップ
HP Stream x360 11-p015wm Motherboard Replacement
必要な工具と部品
  1. HP Stream x360 11-p015wm Motherboard Replacement, Back Cover: 手順 1、 2の画像 1 HP Stream x360 11-p015wm Motherboard Replacement, Back Cover: 手順 1、 2の画像 2
    • Orient the laptop to have the back cover facing upwards.
    • Remove the four rubber pads located in each corner.
  2. HP Stream x360 11-p015wm Motherboard Replacement: 手順 2、 1の画像 1
    • Tool required: JIS #1 Screwdriver
    • Using the screwdriver, remove all of the exposed screws.
  3. HP Stream x360 11-p015wm Motherboard Replacement: 手順 3、 2の画像 1 HP Stream x360 11-p015wm Motherboard Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    iFixit Opening Tool
    $1.99
    • Tool required: iFixit opening tool
    • Open the laptop and orient the keyboard facing upward.
    • Slowly wedge the opening tool into the gap between the keyboard and the back cover.
    • After loosening the back cover, close the laptop and orient the back cover facing upward. Open the cover.
  4. HP Stream x360 11-p015wm Motherboard Replacement: 手順 4、 2の画像 1 HP Stream x360 11-p015wm Motherboard Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    $3.99
    • This is a good time to clean any accumulated dust or debris. Use this link on tips for cleaning.
    • Tool required: Tweezers
    • Carefully use tweezers to remove the audio jack connector from the motherboard.
  5. HP Stream x360 11-p015wm Motherboard Replacement, Motherboard: 手順 5、 1の画像 1
    • Remove the six 6.5 mm Phillips head screws from the battery using the JIS #00 screwdriver.
  6. HP Stream x360 11-p015wm Motherboard Replacement: 手順 6、 3の画像 1 HP Stream x360 11-p015wm Motherboard Replacement: 手順 6、 3の画像 2 HP Stream x360 11-p015wm Motherboard Replacement: 手順 6、 3の画像 3
    • Unplug the wire attaching to the battery to the motherboard using the tweezers.
    • Remove the battery.
  7. HP Stream x360 11-p015wm Motherboard Replacement: 手順 7、 2の画像 1 HP Stream x360 11-p015wm Motherboard Replacement: 手順 7、 2の画像 2
    • Remove the six 3.5 mm screws from the silver plate cover with screwdriver JIS #00.
    • Remove the silver plate cover.
  8. HP Stream x360 11-p015wm Motherboard Replacement: 手順 8、 2の画像 1 HP Stream x360 11-p015wm Motherboard Replacement: 手順 8、 2の画像 2
    • Remove the four 3.5 mm screws from the metal arm using the JIS #00 screwdriver.
  9. HP Stream x360 11-p015wm Motherboard Replacement: 手順 9、 3の画像 1 HP Stream x360 11-p015wm Motherboard Replacement: 手順 9、 3の画像 2 HP Stream x360 11-p015wm Motherboard Replacement: 手順 9、 3の画像 3
    • Detach all remaining wires from the motherboard using the tweezers.
  10. HP Stream x360 11-p015wm Motherboard Replacement: 手順 10、 2の画像 1 HP Stream x360 11-p015wm Motherboard Replacement: 手順 10、 2の画像 2
  11. HP Stream x360 11-p015wm Motherboard Replacement: 手順 11、 2の画像 1 HP Stream x360 11-p015wm Motherboard Replacement: 手順 11、 2の画像 2
    • Remove the six 3.5 mm screws from the motherboard using the JIS #00 screwdriver.
    • Remove the motherboard.
終わりに
作成者
2人の作成者と共同で作成されました。
Meredith Buganski
メンバー登録日: 11/11/19
151 ポイント
1ガイドが承認済み
チーム
IUPUI, Team S2-G3, Stella Fall 2019 IUPUI, Team S2-G3, Stella Fall 2019人のメンバー
IUPUI-STELLA-F19S2G3
3 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 735
