メインコンテンツにスキップ
HP Stream 13-c110nr Display Replacement
必要な工具と部品
  1. HP Stream 13-c110nr Display Replacement, Keyboard Assembly: 手順 1、 1の画像 1
    • Close the device.
    • Remove AC adapter plug from electrical outlet.
    • Remove AC adapter from device.
    • Turn the device off.
    • Unplug all external devices from device.
    • If you are unsure whether the computer is off or in hibernation mode, start the computer and then shutdown the operating system.
  2. HP Stream 13-c110nr Display Replacement: 手順 2、 1の画像 1
    • Turn the device upside down with the back facing towards you.
  3. HP Stream 13-c110nr Display Replacement: 手順 3、 3の画像 1 HP Stream 13-c110nr Display Replacement: 手順 3、 3の画像 2 HP Stream 13-c110nr Display Replacement: 手順 3、 3の画像 3
    • Use a pick to remove the two (2) large computer feet along the back edge of the device.
    • Use a pick to remove the two (2) small computer feet.
    • Use a pick to remove the one (1) screw cover.
    • Place rubber computer feet in safe place for reassembly.
  4. HP Stream 13-c110nr Display Replacement: 手順 4、 3の画像 1 HP Stream 13-c110nr Display Replacement: 手順 4、 3の画像 2 HP Stream 13-c110nr Display Replacement: 手順 4、 3の画像 3
    この手順で使用する道具:
    Magnetic Project Mat
    $19.95
    • Remove the thirteen (13) Phillips P0 PM2.5x6.0 mm screws.
    • Place the thirteen (13) screws on magnetic mat for reassembly.
  5. HP Stream 13-c110nr Display Replacement: 手順 5、 1の画像 1
    • Turn the device over with the front facing towards you.
    • Open the device as shown.
  6. HP Stream 13-c110nr Display Replacement: 手順 6、 3の画像 1 HP Stream 13-c110nr Display Replacement: 手順 6、 3の画像 2 HP Stream 13-c110nr Display Replacement: 手順 6、 3の画像 3
    • Insert the Spudger between the Top Cover and Bottom Cover to lift the front edge until it separates from the Bottom Cover.
    • Do not completely remove the Keyboard/Top cover from the Bottom cover yet.
  7. HP Stream 13-c110nr Display Replacement: 手順 7、 1の画像 1
    • Disconnect the Touchpad cable.
  8. HP Stream 13-c110nr Display Replacement: 手順 8、 2の画像 1 HP Stream 13-c110nr Display Replacement: 手順 8、 2の画像 2
    • Disconnect the Keyboard Cable.
  9. HP Stream 13-c110nr Display Replacement: 手順 9、 2の画像 1 HP Stream 13-c110nr Display Replacement: 手順 9、 2の画像 2
    • Disconnect the Power connector cable.
  10. HP Stream 13-c110nr Display Replacement: 手順 10、 1の画像 1
    • Remove the Keyboard/Top Cover from the device.
  11. HP Stream 13-c110nr Display Replacement, Display Assembly: 手順 11、 1の画像 1
    • Disconnect the Display Cable from the System Board.
  12. HP Stream 13-c110nr Display Replacement: 手順 12、 3の画像 1 HP Stream 13-c110nr Display Replacement: 手順 12、 3の画像 2 HP Stream 13-c110nr Display Replacement: 手順 12、 3の画像 3
    • Remove the four (4) Phillips P0 PM2.5x4.5 mm screws from the screen retaining brackets.
    • Place the four (4) screws on the magnetic mat for reassembly.
  13. HP Stream 13-c110nr Display Replacement: 手順 13、 2の画像 1 HP Stream 13-c110nr Display Replacement: 手順 13、 2の画像 2
    • Peel off two (2) stickers located at the bottom corners of the display assembly.
    • Place two (2) stickers in safe place for reassembly.
  14. HP Stream 13-c110nr Display Replacement: 手順 14、 3の画像 1 HP Stream 13-c110nr Display Replacement: 手順 14、 3の画像 2 HP Stream 13-c110nr Display Replacement: 手順 14、 3の画像 3
    • Remove the two (2) Phillips P0 PM2.5x2.0 mm screws.
    • Place the two (2) screws on the magnetic mat for reassembly.
  15. HP Stream 13-c110nr Display Replacement: 手順 15、 3の画像 1 HP Stream 13-c110nr Display Replacement: 手順 15、 3の画像 2 HP Stream 13-c110nr Display Replacement: 手順 15、 3の画像 3
    • Use a pick to pry off the display cover from the display.
  16. HP Stream 13-c110nr Display Replacement: 手順 16、 1の画像 1
    • Remove the Display Assembly.
  17. HP Stream 13-c110nr Display Replacement: 手順 17、 2の画像 1 HP Stream 13-c110nr Display Replacement: 手順 17、 2の画像 2
    • Remove the four (4) Phillips P0 PM2.5x4.5 mm screws.
    • Place four (4) screws on magnetic mat for reassembly.
    • Remove the two (2) Phillips P0 PM2.5x3.0 mm screws.
    • Place two (2) screws on magnetic mat for reassembly.
  18. HP Stream 13-c110nr Display Replacement: 手順 18、 1の画像 1
    • Separate display from back cover
終わりに
作成者
4人の作成者と共同で作成されました。
Stacey Deel
メンバー登録日: 01/31/19
1,147 ポイント
9のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 12
今までの合計 354
