はじめに
Whether you want to replace a faulty keyboard, or you simply seek to change the look of your notebook, this easy-to-follow guide will instruct you on gaining internal access to the HP Stream 13-c002dx in only two steps.
必要な工具と部品
Flip the laptop over so the bottom is facing up.
Use your Phillips #0 screwdriver to remove the eleven visible 5 mm screws on the back of the laptop.
Unscrew the two remaining 2.5mm screws. Keep these screws separate from the first eleven 5mm screws.
もう少しです!
終わりに
