メインコンテンツにスキップ
HP Stream 13-c002dx Battery Replacement
必要な工具と部品
  1. HP Stream 13-c002dx Battery Replacement, Keyboard: 手順 1、 2の画像 1 HP Stream 13-c002dx Battery Replacement, Keyboard: 手順 1、 2の画像 2
    • Begin by placing your laptop on a clean surface such as a table and away from any liquids which may spill and damage components.
    • Flip the laptop over so the bottom is facing up.
    • Use your Phillips #0 screwdriver to remove the eleven visible 5 mm screws on the back of the laptop.
    • There are some screws underneath the rubber feet. Use a spudger to remove them and gain access.
    • Unscrew the two remaining 2.5mm screws. Keep these screws separate from the first eleven 5mm screws.
  2. HP Stream 13-c002dx Battery Replacement: 手順 2、 3の画像 1 HP Stream 13-c002dx Battery Replacement: 手順 2、 3の画像 2 HP Stream 13-c002dx Battery Replacement: 手順 2、 3の画像 3
    • Flip the laptop back over so it's right side up and open the screen.
    • Using a spudger, separate the keyboard surface from the bottom of the laptop.
    • While lifting the keyboard surface from the bottom, you will notice three cables still attaching them together. Gently unplug each of these cables from the motherboard.
    • Remove the keyboard assembly.
  3. HP Stream 13-c002dx Battery Replacement, Battery: 手順 3、 1の画像 1
    • Use the Phillips #0 to remove four screws from the top of the battery labeled A.
    • Use the Phillips #0 screwdriver to remove four screws labeled holding the battery to the case.
  4. HP Stream 13-c002dx Battery Replacement: 手順 4、 2の画像 1 HP Stream 13-c002dx Battery Replacement: 手順 4、 2の画像 2
    • Coming from the upper middle of the battery, there are cables which connect the battery to the motherboard. Gently remove this group of cables from the socket that it is in on the motherboard.
    • Lift the battery out.
終わりに
2 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Matthew Dodge
メンバー登録日: 01/23/18
416 ポイント
3のガイドは作成済み
チーム
Western Carolina University, Team S1-G1, Virtue Spring 2018 Western Carolina University, Team S1-G1, Virtue Spring 2018人のメンバー
WCU-VIRTUE-S18S1G1
4 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 12
過去 30 日: 26
今までの合計 3,061
