メインコンテンツにスキップ
HP Stream 11-y012nr Battery Replacement
必要な工具と部品
  1. HP Stream 11-y012nr Battery  Replacement, Battery: 手順 1、 3の画像 1 HP Stream 11-y012nr Battery  Replacement, Battery: 手順 1、 3の画像 2 HP Stream 11-y012nr Battery  Replacement, Battery: 手順 1、 3の画像 3
    • Before disassembly, power off the device and unplug it from the charger.
    • Turn the laptop over to access the lower case.
    • Using a metal spudger, remove the two horizontal screw covers.
  2. HP Stream 11-y012nr Battery  Replacement: 手順 2、 2の画像 1 HP Stream 11-y012nr Battery  Replacement: 手順 2、 2の画像 2
    • Remove the seven 5.6 mm Phillips #00 screws.
  3. HP Stream 11-y012nr Battery  Replacement: 手順 3、 3の画像 1 HP Stream 11-y012nr Battery  Replacement: 手順 3、 3の画像 2 HP Stream 11-y012nr Battery  Replacement: 手順 3、 3の画像 3
    • When using the metal spudger, be careful to not press into the components and circuits under the keyboard.
    • Turn the laptop upright and lift the screen.
    • Use the metal spudger to carefully pry the plastic keyboard from the base of the laptop.
    • Work the spudger carefully and slowly around the cover to release the clips holding it together. Be patient since there are a lot of clips attaching the laptop base to the keyboard.
    • Gently lift up the keyboard.
  4. HP Stream 11-y012nr Battery  Replacement: 手順 4、 3の画像 1 HP Stream 11-y012nr Battery  Replacement: 手順 4、 3の画像 2 HP Stream 11-y012nr Battery  Replacement: 手順 4、 3の画像 3
    この手順で使用する道具:
    • The keyboard is attached by three cables. Be careful not to lift the cover too far so you do not damage these cables.
    • Using tweezers, unplug the three cables attached to the keyboard. To do so you will find where the wires end (the three red marks). Use tweezers or your fingers to pinch the plastic piece holding the wires, and gently pull the piece out. After that it should disconnect.
    • Lift up the plastic keyboard cover.
  5. HP Stream 11-y012nr Battery  Replacement: 手順 5、 2の画像 1 HP Stream 11-y012nr Battery  Replacement: 手順 5、 2の画像 2
    • Using tweezers or a plastic spudger, disconnect the two bundled cable connectors connecting the battery to the motherboard.
  6. HP Stream 11-y012nr Battery  Replacement: 手順 6、 3の画像 1 HP Stream 11-y012nr Battery  Replacement: 手順 6、 3の画像 2 HP Stream 11-y012nr Battery  Replacement: 手順 6、 3の画像 3
    • Unscrew the seven 3.3mm Phillips #000 screws.
    • Gently lift the battery out.
終わりに
作成者
3人の作成者と共同で作成されました。
Mahar Senan
メンバー登録日: 02/06/19
233 ポイント
1ガイドが承認済み
チーム
UC Davis, Team S18-G8, Lore Winter 2019 UC Davis, Team S18-G8, Lore Winter 2019人のメンバー
UCD-LORE-W19S18G8
3 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 24
今までの合計 1,558
