メインコンテンツにスキップ
HP Stream 11-r020nr USB Port Replacement
必要な工具と部品
  1. HP Stream 11-r020nr USB Port Replacement, Keyboard Panel: 手順 1、 2の画像 1 HP Stream 11-r020nr USB Port Replacement, Keyboard Panel: 手順 1、 2の画像 2
    • Turn off your HP Stream 11-r020nr by holding the power button down for 10 seconds.
    • Turn the device top down so the rubber feet are facing up.
    • Use a metal spudger to remove all the rubber feet off of the bottom of the device, including the small ones. There will be a total of 11 screws to remove.
  2. HP Stream 11-r020nr USB Port Replacement: 手順 2、 1の画像 1
    • Using the Phillips #1 screwdriver, remove all 11 of the the 5mm screws.
  3. HP Stream 11-r020nr USB Port Replacement: 手順 3、 2の画像 1 HP Stream 11-r020nr USB Port Replacement: 手順 3、 2の画像 2
    • Flip the laptop over and open the laptop.
    • Using the blue plastic opening tool, separate the keyboard plate from the main body by prying up starting around the bottom corners, prying the bottom up first and the sides second all the way around the whole keyboard plate.
    • Be gentle when lifting the keyboard up as there will be ribbon cables still attaching the keyboard to the base of the laptop.
  4. HP Stream 11-r020nr USB Port Replacement: 手順 4、 2の画像 1 HP Stream 11-r020nr USB Port Replacement: 手順 4、 2の画像 2
    • Use the black nylon spudger to flip the black tab up that holds the ribbon cable in place.
    • Lift the ribbon cable free.
  5. HP Stream 11-r020nr USB Port Replacement: 手順 5、 2の画像 1 HP Stream 11-r020nr USB Port Replacement: 手順 5、 2の画像 2
    • Use the black nylon spudger to flip the black tab up that holds the large ribbon cable in place.
    • Pull the ribbon cable free from the base of the keyboard.
  6. HP Stream 11-r020nr USB Port Replacement: 手順 6、 2の画像 1 HP Stream 11-r020nr USB Port Replacement: 手順 6、 2の画像 2
    • Remove the tape covering the ribbon cable.
    • Pull the ribbon cable away from the base of the laptop.
  7. HP Stream 11-r020nr USB Port Replacement: 手順 7、 1の画像 1
    • After detaching the two large ribbon cables, carefully lean the keyboard against the screen.
  8. HP Stream 11-r020nr USB Port Replacement, USB Port: 手順 8、 1の画像 1
    • Using the Phillips #1 screwdriver, remove the single 4mm screw.
    • The USB board is located in the bottom left corner.
  9. HP Stream 11-r020nr USB Port Replacement: 手順 9、 1の画像 1
    • Use the black nylon spudger to flip the tab up that holds the ribbon cable in place.
  10. HP Stream 11-r020nr USB Port Replacement: 手順 10、 1の画像 1
    • Gently pull out the ribbon cable with two fingers.
  11. HP Stream 11-r020nr USB Port Replacement: 手順 11、 1の画像 1
    • Lift the USB port out and remove it from the device.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Victoria McGregor
メンバー登録日: 04/09/18
556 ポイント
4のガイドは作成済み
チーム
コメント 1 件
Thanks for the info…whats the size of the charging port called
Mike Stewart - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 492
