メインコンテンツにスキップ
HP Stream 11-r020nr Charging Port Replacement
必要な工具と部品
  1. HP Stream 11-r020nr Charging Port Replacement, Keyboard Panel: 手順 1、 2の画像 1 HP Stream 11-r020nr Charging Port Replacement, Keyboard Panel: 手順 1、 2の画像 2
    • Turn off your HP Stream 11-r020nr by holding the power button down for 10 seconds.
    • Turn the device top down so the rubber feet are facing up.
    • Use a metal spudger to remove all the rubber feet off of the bottom of the device, including the small ones. There will be a total of 11 screws to remove.
  2. HP Stream 11-r020nr Charging Port Replacement: 手順 2、 1の画像 1
    • Using the Phillips #1 screwdriver, remove all 11 of the the 5mm screws.
  3. HP Stream 11-r020nr Charging Port Replacement: 手順 3、 2の画像 1 HP Stream 11-r020nr Charging Port Replacement: 手順 3、 2の画像 2
    • Flip the laptop over and open the laptop.
    • Using the blue plastic opening tool, separate the keyboard plate from the main body by prying up starting around the bottom corners, prying the bottom up first and the sides second all the way around the whole keyboard plate.
    • Be gentle when lifting the keyboard up as there will be ribbon cables still attaching the keyboard to the base of the laptop.
  4. HP Stream 11-r020nr Charging Port Replacement: 手順 4、 2の画像 1 HP Stream 11-r020nr Charging Port Replacement: 手順 4、 2の画像 2
    • Use the black nylon spudger to flip the black tab up that holds the ribbon cable in place.
    • Lift the ribbon cable free.
  5. HP Stream 11-r020nr Charging Port Replacement: 手順 5、 2の画像 1 HP Stream 11-r020nr Charging Port Replacement: 手順 5、 2の画像 2
    • Use the black nylon spudger to flip the black tab up that holds the large ribbon cable in place.
    • Pull the ribbon cable free from the base of the keyboard.
  6. HP Stream 11-r020nr Charging Port Replacement: 手順 6、 2の画像 1 HP Stream 11-r020nr Charging Port Replacement: 手順 6、 2の画像 2
    • Remove the tape covering the ribbon cable.
    • Pull the ribbon cable away from the base of the laptop.
  7. HP Stream 11-r020nr Charging Port Replacement: 手順 7、 1の画像 1
    • After detaching the two large ribbon cables, carefully lean the keyboard against the screen.
  8. HP Stream 11-r020nr Charging Port Replacement, Charging Port: 手順 8、 1の画像 1
    • Pull the power cable away with your fingers.
  9. HP Stream 11-r020nr Charging Port Replacement: 手順 9、 1の画像 1
    • Using the Phillips #1 screwdriver, remove the 4 mm screw.
  10. HP Stream 11-r020nr Charging Port Replacement: 手順 10、 1の画像 1
    • Lift and remove the charging port from the device.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Victoria McGregor
メンバー登録日: 04/09/18
556 ポイント
4のガイドは作成済み
チーム
2 件のコメント
my hp stream is not charging will be the problem
Nenwarang - 返信
Hp stream 14 is not charging pls help me out battery is dropping down instead of going up
Nenwarang - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 2,624
