メインコンテンツにスキップ
HP Stream 11-d020nr Trackpad Replacement
必要な工具と部品
  1. HP Stream 11-d020nr Trackpad Replacement, Lower Case: 手順 1、 3の画像 1 HP Stream 11-d020nr Trackpad Replacement, Lower Case: 手順 1、 3の画像 2 HP Stream 11-d020nr Trackpad Replacement, Lower Case: 手順 1、 3の画像 3
    • Before disassembly, unplug and power off the Stream 11.
    • Pry off the two elliptical rubber inserts (one in each corner).
    • Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
  2. HP Stream 11-d020nr Trackpad Replacement: 手順 2、 2の画像 1 HP Stream 11-d020nr Trackpad Replacement: 手順 2、 2の画像 2
    • Remove the eleven 5.6 mm Phillips #00 screws.
  3. HP Stream 11-d020nr Trackpad Replacement: 手順 3、 3の画像 1 HP Stream 11-d020nr Trackpad Replacement: 手順 3、 3の画像 2 HP Stream 11-d020nr Trackpad Replacement: 手順 3、 3の画像 3
    • Turn the computer upright and lift the screen.
    • Carefully use a spudger to pry the plastic keyboard cover from the base.
    • When using the metal spudger, be careful not to press into the components underneath the keyboard cover. If possible, use a standard spudger or plastic opening tool to remove the keyboard cover.
    • Work the spudger around the cover to release the clips attaching the cover to the base.
    • Be patient when removing the cover, as there are many clips and it may take some time.
  4. HP Stream 11-d020nr Trackpad Replacement: 手順 4、 3の画像 1 HP Stream 11-d020nr Trackpad Replacement: 手順 4、 3の画像 2 HP Stream 11-d020nr Trackpad Replacement: 手順 4、 3の画像 3
    • Disconnect the cable connecting the ClickPad to the base.
    • Remove the plastic keyboard cover.
    • The cover is attached to the ClickPad by a cable. Be careful not to lift the cover too far so you do not damage this cable.
  5. HP Stream 11-d020nr Trackpad Replacement, Trackpad: 手順 5、 2の画像 1 HP Stream 11-d020nr Trackpad Replacement, Trackpad: 手順 5、 2の画像 2
    • On the back of the plastic keyboard cover, remove the two 2 mm Phillips #000 screws.
  6. HP Stream 11-d020nr Trackpad Replacement: 手順 6、 1の画像 1
    • Lift up the plastic cover to release the ClickPad.
終わりに
To reassemble your computer, follow these instructions in reverse order.
4 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Spenser Mason
メンバー登録日: 02/04/16
1,763 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 3-5, Wollert Spring 2016 USF Tampa, Team 3-5, Wollert Spring 2016人のメンバー
USFT-WOLLERT-S16S3G5
5 メンバー
19のガイドは作成済み
2件のガイドコメント
windows 8.1 y windows 10 no detectan el clickpad ni en el administrador de dispositivos, como si no existiera pero al arrancar de un cdlive de ubuntu lo reconoce perfectamente. alguien sabra que podria ser?
Oscar - 返信
Can you give the Product number of the part?
NÖME Technologys and Designs - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 1,578
