メインコンテンツにスキップ
HP Stream 11-d020nr Lid Replacement
必要な工具と部品
  1. HP Stream 11-d020nr Lid Replacement, Lower Case: 手順 1、 3の画像 1 HP Stream 11-d020nr Lid Replacement, Lower Case: 手順 1、 3の画像 2 HP Stream 11-d020nr Lid Replacement, Lower Case: 手順 1、 3の画像 3
    • Before disassembly, unplug and power off the Stream 11.
    • Pry off the two elliptical rubber inserts (one in each corner).
    • Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
  2. HP Stream 11-d020nr Lid Replacement: 手順 2、 2の画像 1 HP Stream 11-d020nr Lid Replacement: 手順 2、 2の画像 2
    • Remove the eleven 5.6 mm Phillips #00 screws.
  3. HP Stream 11-d020nr Lid Replacement: 手順 3、 3の画像 1 HP Stream 11-d020nr Lid Replacement: 手順 3、 3の画像 2 HP Stream 11-d020nr Lid Replacement: 手順 3、 3の画像 3
    • Turn the computer upright and lift the screen.
    • Carefully use a spudger to pry the plastic keyboard cover from the base.
    • When using the metal spudger, be careful not to press into the components underneath the keyboard cover. If possible, use a standard spudger or plastic opening tool to remove the keyboard cover.
    • Work the spudger around the cover to release the clips attaching the cover to the base.
    • Be patient when removing the cover, as there are many clips and it may take some time.
  4. HP Stream 11-d020nr Lid Replacement: 手順 4、 3の画像 1 HP Stream 11-d020nr Lid Replacement: 手順 4、 3の画像 2 HP Stream 11-d020nr Lid Replacement: 手順 4、 3の画像 3
    • Disconnect the cable connecting the ClickPad to the base.
    • Remove the plastic keyboard cover.
    • The cover is attached to the ClickPad by a cable. Be careful not to lift the cover too far so you do not damage this cable.
  5. HP Stream 11-d020nr Lid Replacement, Keyboard: 手順 5、 2の画像 1 HP Stream 11-d020nr Lid Replacement, Keyboard: 手順 5、 2の画像 2
    • Tilt the top of the keyboard plate up until you separate it from the base.
    • Tilt the keyboard toward you slowly but do not remove it, it is still connected with ribbon cables.
  6. HP Stream 11-d020nr Lid Replacement: 手順 6、 3の画像 1 HP Stream 11-d020nr Lid Replacement: 手順 6、 3の画像 2 HP Stream 11-d020nr Lid Replacement: 手順 6、 3の画像 3
    • Lift up the retaining flaps on the ZIF connectors securing the two keyboard ribbon cables.
    • After disengaging the connectors, gently unplug both ribbon cables.
  7. HP Stream 11-d020nr Lid Replacement, Lid: 手順 7、 3の画像 1 HP Stream 11-d020nr Lid Replacement, Lid: 手順 7、 3の画像 2 HP Stream 11-d020nr Lid Replacement, Lid: 手順 7、 3の画像 3
    • Lift the black flap on the display cable ZIF connector.
    • After lifting the flap, gently pull the display cable from its socket.
    • Disconnect the wireless antenna from the wireless card.
    • Remove the four 2.2 mm Phillips #00 screws on the left and right sides of the laptop.
  8. HP Stream 11-d020nr Lid Replacement: 手順 8、 3の画像 1 HP Stream 11-d020nr Lid Replacement: 手順 8、 3の画像 2 HP Stream 11-d020nr Lid Replacement: 手順 8、 3の画像 3
    この手順で使用する道具:
    • Use tweezers to remove the screw covers from the lid.
    • Remove the two 2.2 mm Phillips #000 screws.
    • Use a plastic opening tool to disengage the front part of the lid.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Spenser Mason
メンバー登録日: 02/04/16
1,763 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 3-5, Wollert Spring 2016 USF Tampa, Team 3-5, Wollert Spring 2016人のメンバー
USFT-WOLLERT-S16S3G5
5 メンバー
19のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 536
