メインコンテンツにスキップ
HP Stream 11-d010nr Speaker Replacement
必要な工具と部品
  1. HP Stream 11-d010nr Speaker Replacement, Pry out the inserts: 手順 1、 2の画像 1 HP Stream 11-d010nr Speaker Replacement, Pry out the inserts: 手順 1、 2の画像 2
    • Unplug and turn off the HP Stream 11 before disassembling the device.
    • Using a spudger, gently pry off the two elliptical rubber inserts located in the top corners.
    • Carefully remove the two circular rubber inserts positioned beneath the removed elliptical inserts.
  2. HP Stream 11-d010nr Speaker Replacement, Unscrew the back cover: 手順 2、 1の画像 1
    • Using a Phillips #1 screwdriver, remove the eleven 5.6 mm screws securing the back cover.
    • Keep the screws in a safe place for reassembly.
  3. HP Stream 11-d010nr Speaker Replacement, Pry the keyboard casing up: 手順 3、 2の画像 1 HP Stream 11-d010nr Speaker Replacement, Pry the keyboard casing up: 手順 3、 2の画像 2
    • Using an iFixit opening tool, carefully pry open the case to separate the keyboard from the main body. Work slowly to avoid damaging the edges.
    • HP Stream 11s tend to be really difficult to open. If your device is not opening with a standard iFixit opening tool, use a nylon spudger, then the metal spudger, or a metal Jimmy as the last resort.
    • When using the metal spudger or Jimmy, be careful not to bring these tools into contact with any electronic components of the device as this can damage the device.
  4. HP Stream 11-d010nr Speaker Replacement, Identify the connectors: 手順 4、 1の画像 1
    • Carefully lift the keyboard and identify the three ribbon cables connecting the main body of the laptop to the keyboard.
    • Lift the keyboard with extreme care to avoid damaging the delicate ribbon cables. Applying excessive force can easily tear or break them easily.
  5. HP Stream 11-d010nr Speaker Replacement, Disconnect the cables: 手順 5、 3の画像 1 HP Stream 11-d010nr Speaker Replacement, Disconnect the cables: 手順 5、 3の画像 2 HP Stream 11-d010nr Speaker Replacement, Disconnect the cables: 手順 5、 3の画像 3
    • Using a spudger, gently lift the flaps on the ZIF connectors to release the three ribbon cables securely attached to them.
    • Carefully disconnect the three ribbon cables.
  6. HP Stream 11-d010nr Speaker Replacement, Lift the keyboard out: 手順 6、 1の画像 1
    • Gently lift the keyboard out of the laptop to fully detach it from the device.
    • While handling, avoid damaging any remaining components.
  7. HP Stream 11-d010nr Speaker Replacement, Speaker: 手順 7、 1の画像 1
    • Using a Phillips #000 screwdriver, remove the four 3mm screws securing the speaker in place.
    • Keep the screws in a safe location for reuse during the installation of the replacement speaker.
  8. HP Stream 11-d010nr Speaker Replacement: 手順 8、 1の画像 1
    • Carefully disconnect the wire connecting the speaker to the motherboard.
    • Use tweezers if needed, to avoid damaging the delicate connectors.
  9. HP Stream 11-d010nr Speaker Replacement: 手順 9、 1の画像 1
    • After disconnecting the speaker from the computer hardware, carefully lift it out of its slot and place it in a safe location.
終わりに
作成者
9人の作成者と共同で作成されました。
Tristan Thompson
メンバー登録日: 10/03/22
97 ポイント
1ガイドが承認済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 205
