はじめに
Sometimes the keyboard of an HP Stream 11-d010nr will start to behave sub optimally, such as unresponsive or sticky keys. This guide will show you how to replace it.
必要な工具と部品
Pry off the two elliptical rubber inserts (one in each corner).
Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
ある他の人がこのガイドを完成しました。
2 件のコメント
I feel like the 5-10 minutes estimated time is way too short for this repair (however, I have not done this, and may be wrong).
There will definitely be variation depending on each individual but our group came to the conclusion that this was a reasonable time frame. I appreciate the feedback though and if anyone else reaches out saying it is too short I will increase the estimated time. Thank you!
