メインコンテンツにスキップ
HP Stream 11-d008TU Battery Connector Unplugging
必要な工具と部品
  1. HP Stream 11-d008TU Battery Connector Unplugging, Rubber Feet Removal: 手順 1、 3の画像 1 HP Stream 11-d008TU Battery Connector Unplugging, Rubber Feet Removal: 手順 1、 3の画像 2 HP Stream 11-d008TU Battery Connector Unplugging, Rubber Feet Removal: 手順 1、 3の画像 3
    • Use a prying tool to pry the 2 rubber feet off closest to the hinge of the device
    • Repeat this process for the other side of the device
    • The bottom rubber feet do not have hidden screws underneath them, and as such, they are unnecessary to remove
  2. HP Stream 11-d008TU Battery Connector Unplugging, Screw removal: 手順 2、 2の画像 1 HP Stream 11-d008TU Battery Connector Unplugging, Screw removal: 手順 2、 2の画像 2
    • Remove the 11x 5mm Phillips PH-0 screws (circled)
  3. HP Stream 11-d008TU Battery Connector Unplugging, Keyboard Unclipping: 手順 3、 3の画像 1 HP Stream 11-d008TU Battery Connector Unplugging, Keyboard Unclipping: 手順 3、 3の画像 2 HP Stream 11-d008TU Battery Connector Unplugging, Keyboard Unclipping: 手順 3、 3の画像 3
    • Use your finger to pry the outer blue shell over the keyboard
    • Continue this process around the edges of the device
    • You may have to use a prying tool to pry the harder edges such as around the I/O ports
    • Do not lift the keyboard once all the clips are undone, as there are still various cables connected
  4. HP Stream 11-d008TU Battery Connector Unplugging, Keyboard removal: 手順 4、 3の画像 1 HP Stream 11-d008TU Battery Connector Unplugging, Keyboard removal: 手順 4、 3の画像 2 HP Stream 11-d008TU Battery Connector Unplugging, Keyboard removal: 手順 4、 3の画像 3
    • Disconnect the power button connector by peeling back the protective tape, using your fingernail to flip the white retaining clip back, and pulling the ribbon cable out
    • Disconnect the touchpad connector by using your fingernail to flip the black retaining clip back, and pulling the ribbon cable out
    • Disconnect the keyboard connector by using your fingernail to flip the black retaining clip back, and pulling the ribbon cable out
    • Your keyboard assembly is now safe to remove
  5. HP Stream 11-d008TU Battery Connector Unplugging, Battery Connector: 手順 5、 3の画像 1 HP Stream 11-d008TU Battery Connector Unplugging, Battery Connector: 手順 5、 3の画像 2 HP Stream 11-d008TU Battery Connector Unplugging, Battery Connector: 手順 5、 3の画像 3
    • Locate the white plastic connector on the motherboard
    • Peel back the black tape holding the cable's wires in place
    • Pull the white connector out by puling the white plastic away from the connector
    • Do not grab the connector by the wires
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Joel Taylor
メンバー登録日: 03/07/20
1,298 ポイント
8のガイドは作成済み
チーム
Australia Australia人のメンバー
Community
4 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 104
