メインコンテンツにスキップ
HP Star Wars Special Edition 15-an051dx Battery Replacement
  1. HP Star Wars Special Edition 15-an051dx Battery Replacement, Battery: 手順 1、 3の画像 1 HP Star Wars Special Edition 15-an051dx Battery Replacement, Battery: 手順 1、 3の画像 2 HP Star Wars Special Edition 15-an051dx Battery Replacement, Battery: 手順 1、 3の画像 3
    • Make sure the device is fully powered down and unplugged from external power.
    • Close the device and turn it over so it will be on its back.
  2. HP Star Wars Special Edition 15-an051dx Battery Replacement: 手順 2、 3の画像 1 HP Star Wars Special Edition 15-an051dx Battery Replacement: 手順 2、 3の画像 2 HP Star Wars Special Edition 15-an051dx Battery Replacement: 手順 2、 3の画像 3
    • In the red is the battery and the battery's holding/locking latches.
    • Slide the latches in the direction the arrows face. This will unlock and release the battery.
    • Set the old battery aside or dispose of properly by following the manufacturers instructions written on the battery or check online of battery disposal services.
  3. HP Star Wars Special Edition 15-an051dx Battery Replacement: 手順 3、 3の画像 1 HP Star Wars Special Edition 15-an051dx Battery Replacement: 手順 3、 3の画像 2 HP Star Wars Special Edition 15-an051dx Battery Replacement: 手順 3、 3の画像 3
    • Check the battery port on your device and make sure it is clear of debris and pins are not bent or damaged.
    • Install the new battery into the port and press down gently.
    • Make sure it latches on to its locking clip.
    • Once installed and you have followed the battery manufacturer's instructions, turn your device on to its upright position and boot your device.
終わりに
Device should be working as usual with the new battery.
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Fernando Mendez
メンバー登録日: 08/25/22
643 ポイント
5のガイドは作成済み
チーム
Gateway, Team 1-2, Pee Fall 2022 Gateway, Team 1-2, Pee Fall 2022人のメンバー
GCC-PEE-F22S1G2
4 メンバー
5のガイドは作成済み
コメント 1 件
Altho this a simple fix some people still have a hard time removing the battery so thank you very much
RETRO GAMEHEAD - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 19
今までの合計 274
