メインコンテンツにスキップ
HP Split x2 13-g210dx Speakers Replacement
必要な工具と部品
  1. HP Split x2 13-g210dx Speakers Replacement, Back Panel: 手順 1、 1の画像 1
    • Carefully peel off the felt cover that is found beneath the display along the bottom of the device.
    • Use a spudger to gently scrape away the padding that hides the screws in each of the four locations.
    • Remove the four 4-mm Phillips #0 screws.
    • Run a spudger along the crease of the entire laptop and slowly pry off the back panel of the device, beginning with the bottom edge.
    • You will hear popping noises as the clips separate from each other.
  2. HP Split x2 13-g210dx Speakers Replacement, Battery: 手順 2、 1の画像 1
    • Remove the three 6-mm Phillips #0 screws.
  3. HP Split x2 13-g210dx Speakers Replacement: 手順 3、 2の画像 1 HP Split x2 13-g210dx Speakers Replacement: 手順 3、 2の画像 2
    • Remove the white connector clip from the connector port using a sturdy tweezers.
  4. HP Split x2 13-g210dx Speakers Replacement: 手順 4、 2の画像 1 HP Split x2 13-g210dx Speakers Replacement: 手順 4、 2の画像 2
    • Lift the battery away from the device.
  5. HP Split x2 13-g210dx Speakers Replacement, Docking Port: 手順 5、 1の画像 1
    • Remove the two 4-mm Phillips #0 screws.
  6. HP Split x2 13-g210dx Speakers Replacement: 手順 6、 2の画像 1 HP Split x2 13-g210dx Speakers Replacement: 手順 6、 2の画像 2
    • Remove the clips from the docking port board with a sturdy pair of tweezers.
  7. HP Split x2 13-g210dx Speakers Replacement: 手順 7、 2の画像 1 HP Split x2 13-g210dx Speakers Replacement: 手順 7、 2の画像 2
    • Remove the two ribbons labeled "Dock" at the top of the docking port board using tweezers or a sturdy plastic opening tool.
  8. HP Split x2 13-g210dx Speakers Replacement: 手順 8、 1の画像 1
    • Lift the docking port away from the device.
  9. HP Split x2 13-g210dx Speakers Replacement, SD Port: 手順 9、 1の画像 1
  10. HP Split x2 13-g210dx Speakers Replacement: 手順 10、 2の画像 1 HP Split x2 13-g210dx Speakers Replacement: 手順 10、 2の画像 2
    • Remove the yellow ribbon labeled "SD" in the left corner of the SD port board using tweezers or a sturdy plastic opening tool.
  11. HP Split x2 13-g210dx Speakers Replacement: 手順 11、 1の画像 1
    • Lift the SD port away from the device.
  12. HP Split x2 13-g210dx Speakers Replacement, Audio Port: 手順 12、 1の画像 1
  13. HP Split x2 13-g210dx Speakers Replacement: 手順 13、 3の画像 1 HP Split x2 13-g210dx Speakers Replacement: 手順 13、 3の画像 2 HP Split x2 13-g210dx Speakers Replacement: 手順 13、 3の画像 3
    • Remove the two purple ribbons labeled "Audio" at the top of the audio port board using tweezers or a sturdy plastic opening tool.
  14. HP Split x2 13-g210dx Speakers Replacement: 手順 14、 2の画像 1 HP Split x2 13-g210dx Speakers Replacement: 手順 14、 2の画像 2
    • Remove the white clip at the top right corner of the audio port board using tweezers.
  15. HP Split x2 13-g210dx Speakers Replacement: 手順 15、 1の画像 1
    • Lift the Audio port away from the device.
  16. HP Split x2 13-g210dx Speakers Replacement, Speakers: 手順 16、 2の画像 1 HP Split x2 13-g210dx Speakers Replacement, Speakers: 手順 16、 2の画像 2
    • Remove the 4-mm Phillips #0 screw.
    • Lift the left speaker away from the device.
  17. HP Split x2 13-g210dx Speakers Replacement: 手順 17、 2の画像 1 HP Split x2 13-g210dx Speakers Replacement: 手順 17、 2の画像 2
    • Remove the 4-mm Phillips #0 screw from the same location as found on the left speaker.
    • Lift the right speaker away from the device.
  18. HP Split x2 13-g210dx Speakers Replacement: 手順 18、 3の画像 1 HP Split x2 13-g210dx Speakers Replacement: 手順 18、 3の画像 2 HP Split x2 13-g210dx Speakers Replacement: 手順 18、 3の画像 3
    • Carefully remove the bonded white and black speaker wires running along the bottom of the control board from the fastening clips.
    • Lift the speaker assembly away from the device.
終わりに
作成者
2人の作成者と共同で作成されました。
Darian Devries
メンバー登録日: 02/25/19
495 ポイント
4のガイドは作成済み
チーム
Purdue University Northwest, Team S4-G1, Hingst Spring 2019 Purdue University Northwest, Team S4-G1, Hingst Spring 2019人のメンバー
PNW-HINGST-S19S4G1
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 263
