メインコンテンツにスキップ
HP Split 13-r010dx Speaker Replacement
必要な工具と部品
  1. HP Split 13-r010dx Speaker Replacement, Front and Back Panel: 手順 1、 2の画像 1 HP Split 13-r010dx Speaker Replacement, Front and Back Panel: 手順 1、 2の画像 2
    • Locate the four screws at the bottom of the device. (Note that the keyboard attachment is missing from this device.)
    • Use a Philips head #0 screwdriver to remove each of the screws (Size: 4mm)
  2. HP Split 13-r010dx Speaker Replacement: 手順 2、 2の画像 1 HP Split 13-r010dx Speaker Replacement: 手順 2、 2の画像 2
    • Gently wedge the plastic opening tool in between where the display and back panel meet.
    • Slowly and gently apply force to the plastic opening tool in a downwards motion to loosen the front panel from the back panel.
    • Rotate the device so that the side is facing up and repeat the previous step for the sides.
    • Do NOT attempt to wedge the plastic opening tool on the bottom . Once the sides and top are loose you are ready to continue to the next step.
  3. HP Split 13-r010dx Speaker Replacement: 手順 3、 1の画像 1
    • Gently and slowly pull the front and back panel away from each other (in opposite directions). ( Pulling them apart will not separate the two panels)
    • Only separate the panels by a few inches from each other so that there is room to separate the front and back panel in the next step. Proceed to the next step.
  4. HP Split 13-r010dx Speaker Replacement: 手順 4、 1の画像 1
    • Hold the back panel firmly and pull the front panel upwards to completely separate the front panel from the back panel.
    • The device is now ready to be repaired or replacements installed.
  5. HP Split 13-r010dx Speaker Replacement, Speaker: 手順 5、 1の画像 1
    • Using the PH 0 screw head unscrew each of the screws located int the upper right of the speakers.
  6. HP Split 13-r010dx Speaker Replacement: 手順 6、 2の画像 1 HP Split 13-r010dx Speaker Replacement: 手順 6、 2の画像 2
    この手順で使用する道具:
    購入する
    • After unscrewing the speakers, gently lift the speaker out using the tweezers.
  7. HP Split 13-r010dx Speaker Replacement: 手順 7、 2の画像 1 HP Split 13-r010dx Speaker Replacement: 手順 7、 2の画像 2
    • Once each speaker is out, remove the center plate in between the speakers, using the PH0 bit.
  8. HP Split 13-r010dx Speaker Replacement: 手順 8、 3の画像 1 HP Split 13-r010dx Speaker Replacement: 手順 8、 3の画像 2 HP Split 13-r010dx Speaker Replacement: 手順 8、 3の画像 3
    • After removing the the speakers completely, using the tweezers gently remove the micro chip connection from the system.
    • Then untwist the wires from the thick black cord.
    • Be careful when pulling the cord underneath the plug-ins marked in red. They may unplug.
終わりに
作成者
3人の作成者と共同で作成されました。
Kim
メンバー登録日: 09/26/17
201 ポイント
2のガイドは作成済み
チーム
University of North Texas, Team S2-G1, Thompson Fall 2017 University of North Texas, Team S2-G1, Thompson Fall 2017人のメンバー
UNT-THOMPSON-F17S2G1
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 7
今までの合計 138
