メインコンテンツにスキップ
HP Spectrex360 13-ac023dx Display Replacement
必要な工具と部品
  1. HP Spectrex360 13-ac023dx Display Replacement, Battery: 手順 1、 2の画像 1 HP Spectrex360 13-ac023dx Display Replacement, Battery: 手順 1、 2の画像 2
    • Flip the laptop over so the model sticker faces the ceiling.
  2. HP Spectrex360 13-ac023dx Display Replacement: 手順 2、 3の画像 1 HP Spectrex360 13-ac023dx Display Replacement: 手順 2、 3の画像 2 HP Spectrex360 13-ac023dx Display Replacement: 手順 2、 3の画像 3
    • Use a Torx #5 screwdriver to remove the six 3.5 mm screws holding the back cover to the laptop.
  3. HP Spectrex360 13-ac023dx Display Replacement: 手順 3、 2の画像 1 HP Spectrex360 13-ac023dx Display Replacement: 手順 3、 2の画像 2
    • Use the Phillips #000 screwdriver to remove the four 3.5 mm screws holding the battery.
    • After removing the screws, detach the battery wire from the mother board with the iFixit opening tool.
    • Then, carefully lift the battery off with the iFixit opening tool.
  4. HP Spectrex360 13-ac023dx Display Replacement, Display: 手順 4、 1の画像 1
    • Lay the laptop flat on the table with the keyboard side facing the table and the motherboard facing up.
  5. HP Spectrex360 13-ac023dx Display Replacement: 手順 5、 3の画像 1 HP Spectrex360 13-ac023dx Display Replacement: 手順 5、 3の画像 2 HP Spectrex360 13-ac023dx Display Replacement: 手順 5、 3の画像 3
    • Using the Phillips #000 screwdriver, remove the four 1.0 mm screws that attach the display to the main body of the computer.
  6. HP Spectrex360 13-ac023dx Display Replacement: 手順 6、 3の画像 1 HP Spectrex360 13-ac023dx Display Replacement: 手順 6、 3の画像 2 HP Spectrex360 13-ac023dx Display Replacement: 手順 6、 3の画像 3
    • Move the metal components that were just unscrewed out of the way to make a clear view of the two display connectors.
    • Flip up both latches that are found at the center of the computer's body where the wires connect to the motherboard. Then release the wires that attach to the display. This will separate the two main parts of the computer.
  7. HP Spectrex360 13-ac023dx Display Replacement: 手順 7、 2の画像 1 HP Spectrex360 13-ac023dx Display Replacement: 手順 7、 2の画像 2
    • Separate the display from the bottom half of the computer(motherboard).
終わりに
2 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Jonathan
メンバー登録日: 10/21/19
486 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team S1-G6, Botvin Fall 2019 UMass Dartmouth, Team S1-G6, Botvin Fall 2019人のメンバー
UMASSD-BOTVIN-F19S1G6
3 メンバー
6のガイドは作成済み
コメント 1 件
I couldn’t remove the display without removing the one speaker. In the pictures, you can easily see that he just bent the metal case at the hinge and pried it out.
Ryan Stauffer - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 14
過去 30 日: 70
今までの合計 2,527
