メインコンテンツにスキップ
HP Spectre x360 15-bl012dx SSD Replacement
必要な工具と部品
  1. HP Spectre x360 15-bl012dx SSD Replacement, Battery Replacement: 手順 1、 2の画像 1 HP Spectre x360 15-bl012dx SSD Replacement, Battery Replacement: 手順 1、 2の画像 2
    • Power off the device before beginning disassembly.
    • Place the computer so that the back panel is facing up. Begin by removing the two visible Torx T5 9 mm screws near the hinges.
    • Next, remove the four visible Torx T5 3 mm on the sides.
    • Keep track of all screws.
  2. HP Spectre x360 15-bl012dx SSD Replacement: 手順 2、 3の画像 1 HP Spectre x360 15-bl012dx SSD Replacement: 手順 2、 3の画像 2 HP Spectre x360 15-bl012dx SSD Replacement: 手順 2、 3の画像 3
    • Please note the upper two feet are already removed. The device was given to us this way.
    • Remove the two upper feet using an opening tool or spudger if they are still in place. The upper feet are closer to the hinges for the screen.
    • Remove the two 8 mm Phillips #1 screws under the feet.
    • These are the final screws to remove from the back panel. In total, you should remove eight screws between Steps 1 and 2.
  3. HP Spectre x360 15-bl012dx SSD Replacement: 手順 3、 1の画像 1
    • Use a spudger to pry the back panel off of the laptop. Work your way around the perimeter of the device to loosen the connection.
    • Take the back panel off of the laptop.
  4. HP Spectre x360 15-bl012dx SSD Replacement: 手順 4、 1の画像 1
    • Use a Phillips #1 screwdriver to remove six 4 mm screws securing the battery.
  5. HP Spectre x360 15-bl012dx SSD Replacement: 手順 5、 3の画像 1 HP Spectre x360 15-bl012dx SSD Replacement: 手順 5、 3の画像 2 HP Spectre x360 15-bl012dx SSD Replacement: 手順 5、 3の画像 3
    • Unplug the battery connector located on the motherboard.
    • Remove the battery from the laptop.
  6. HP Spectre x360 15-bl012dx SSD Replacement, Solid State Drive (SSD): 手順 6、 3の画像 1 HP Spectre x360 15-bl012dx SSD Replacement, Solid State Drive (SSD): 手順 6、 3の画像 2 HP Spectre x360 15-bl012dx SSD Replacement, Solid State Drive (SSD): 手順 6、 3の画像 3
    • Using minimal force, lift the locking bars on the USB board ZIF connector using a plastic opening tool or fingernail and pull out the ribbon cable.
  7. HP Spectre x360 15-bl012dx SSD Replacement: 手順 7、 1の画像 1
    • Using your fingers, remove the USB ribbon cable from the motherboard above the fan.
  8. HP Spectre x360 15-bl012dx SSD Replacement: 手順 8、 2の画像 1 HP Spectre x360 15-bl012dx SSD Replacement: 手順 8、 2の画像 2
    • Remove the 3 mm Phillips #1 screw that secures the solid state drive to the board.
    • Please note this laptop was not supplied with an SSD, so this is not the same SSD you will find in your device.
  9. HP Spectre x360 15-bl012dx SSD Replacement: 手順 9、 1の画像 1
    • Slide the SSD card out of the connection at a 45 degree angle so that the SSD teeth are not bent.
終わりに
作成者
5人の作成者と共同で作成されました。
Cade Caldwell
メンバー登録日: 02/22/22
193 ポイント
2のガイドは作成済み
チーム
Clemson, Team 1-1, Hunter Spring 2022 Clemson, Team 1-1, Hunter Spring 2022人のメンバー
CLEM-HUNTER-S22S1G1
5 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 20
過去 30 日: 79
今までの合計 849
