メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP Spectre x360 15" (15t-ap000) SSD Replacement
必要な工具と部品
  1. HP Spectre x360 15" (15t-ap000) SSD Replacement, Unscrew the back cover: 手順 1、 1の画像 1
    • Be sure to completely power off and unplug your laptop before you begin your repair. Make sure the laptop is not in standby, sleep, or hibernation mode.
    • Use a T5 driver to remove the following screws securing the back cover:
    • Six 4 mm-long screws
    • Two 7.8 mm-long screws
    FixBotに聞いてみる
    コメントを追加
  2. HP Spectre x360 15" (15t-ap000) SSD Replacement, Loosen the back cover: 手順 2、 2の画像 1 HP Spectre x360 15" (15t-ap000) SSD Replacement, Loosen the back cover: 手順 2、 2の画像 2
    • Use an opening tool or your fingers to pry up the back cover from the laptop.
    • Plastic clips hold the back cover lightly in place, so you may encounter some resistance.
    • If it feels like there is strong resistance, you may have a model that includes screws under the corner feet. Carefully pry the feet up to make sure they don't have screws.
    FixBotに聞いてみる
    コメントを追加
  3. HP Spectre x360 15" (15t-ap000) SSD Replacement, Remove the back cover: 手順 3、 2の画像 1 HP Spectre x360 15" (15t-ap000) SSD Replacement, Remove the back cover: 手順 3、 2の画像 2
    • Lift and remove the back cover.
    • During reassembly, gently press along the perimeter of the back cover to re-engage the clips.
    FixBotに聞いてみる
    コメントを追加
  4. HP Spectre x360 15" (15t-ap000) SSD Replacement, Disconnect the battery: 手順 4、 3の画像 1 HP Spectre x360 15" (15t-ap000) SSD Replacement, Disconnect the battery: 手順 4、 3の画像 2 HP Spectre x360 15" (15t-ap000) SSD Replacement, Disconnect the battery: 手順 4、 3の画像 3
    • Pry the edges of the battery connector with a spudger to loosen the connector from its motherboard socket.
    • Gently pull the connector parallel to the motherboard to disconnect it.
    FixBotに聞いてみる
    コメントを追加
  5. HP Spectre x360 15" (15t-ap000) SSD Replacement, Remove the SSD: 手順 5、 2の画像 1 HP Spectre x360 15" (15t-ap000) SSD Replacement, Remove the SSD: 手順 5、 2の画像 2
    この手順で使用する道具:
    • Use your fingers or tweezers to peel the black plastic strip until you uncover the SSD.
    FixBotに聞いてみる
    コメントを追加
  6. HP Spectre x360 15" (15t-ap000) SSD Replacement: 手順 6、 1の画像 1
    • Use a Phillips screwdriver to remove the 2.8 mm-long screw securing the SSD to the motherboard.
    FixBotに聞いてみる
    コメントを追加
  7. HP Spectre x360 15" (15t-ap000) SSD Replacement: 手順 7、 2の画像 1 HP Spectre x360 15" (15t-ap000) SSD Replacement: 手順 7、 2の画像 2
    • Grasp the SSD edges with your fingers and pull it at a shallow angle parallel to the motherboard.
    • Remove the SSD.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Arthur Shi
メンバー登録日: 01/03/18
336,447 ポイント
848のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
122 メンバー
25,810のガイドは作成済み
1件のガイドコメント
There are several types of M.2 slot supporting different technology, SATA or NVMe, so the first claim in the into is incorrect. Additionally, they are different sizes.
Ed Maher - 返信 共有
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 18
過去 30 日: 91
今までの合計 5,099
