メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP Spectre x360 15" (15t-ap000) Battery Replacement
必要な工具と部品
  1. HP Spectre x360 15" (15t-ap000) Battery Replacement, Unscrew the back cover: 手順 1、 1の画像 1
    • Be sure to completely power off and unplug your laptop before you begin your repair. Make sure the laptop is not in standby, sleep, or hibernation mode.
    • Use a T5 driver to remove the following screws securing the back cover:
    • Six 4 mm-long screws
    • Two 7.8 mm-long screws
  2. HP Spectre x360 15" (15t-ap000) Battery Replacement, Loosen the back cover: 手順 2、 2の画像 1 HP Spectre x360 15" (15t-ap000) Battery Replacement, Loosen the back cover: 手順 2、 2の画像 2
    • Use an opening tool or your fingers to pry up the back cover from the laptop.
    • Plastic clips hold the back cover lightly in place, so you may encounter some resistance.
    • If it feels like there is strong resistance, you may have a model that includes screws under the corner feet. Carefully pry the feet up to make sure they don't have screws.
  3. HP Spectre x360 15" (15t-ap000) Battery Replacement, Remove the back cover: 手順 3、 2の画像 1 HP Spectre x360 15" (15t-ap000) Battery Replacement, Remove the back cover: 手順 3、 2の画像 2
    • Lift and remove the back cover.
    • During reassembly, gently press along the perimeter of the back cover to re-engage the clips.
  4. HP Spectre x360 15" (15t-ap000) Battery Replacement, Disconnect the battery: 手順 4、 3の画像 1 HP Spectre x360 15" (15t-ap000) Battery Replacement, Disconnect the battery: 手順 4、 3の画像 2 HP Spectre x360 15" (15t-ap000) Battery Replacement, Disconnect the battery: 手順 4、 3の画像 3
    • Pry the edges of the battery connector with a spudger to loosen the connector from its motherboard socket.
    • Gently pull the connector parallel to the motherboard to disconnect it.
  5. HP Spectre x360 15" (15t-ap000) Battery Replacement, Remove the battery: 手順 5、 1の画像 1
    • Use a Phillips screwdriver to remove the five 4.3 mm-long screws securing the battery to the laptop.
  6. HP Spectre x360 15" (15t-ap000) Battery Replacement: 手順 6、 2の画像 1 HP Spectre x360 15" (15t-ap000) Battery Replacement: 手順 6、 2の画像 2
    • Lift and remove the battery from the laptop.
終わりに
For optimal performance, after completing this guide, calibrate your newly installed battery.
ある他の人がこのガイドを完成しました。
Arthur Shi
メンバー登録日: 01/03/18
334,109 ポイント
847のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
25,530のガイドは作成済み
4件のガイドコメント
I have the same model, but there are screws under the two rear rubber feet. I damaged one of the feet during removal ):
Miguel Medina - 返信 共有
I'm sorry to hear that! I double-checked my laptop, and it doesn't have the two feet. Perhaps there was a hardware update. I'll add a note in the guides.
Arthur Shi - 共有
So the battery shown/listed in the store is a PK03XL but the images (and my laptop) clearly have the PG03XL model which has higher amp hours. Also, the PK0 does not fit.
Karim T - 返信 共有
Hi Karim,
That's correct! The PK03XL battery that's sold in the iFixit store is for the 13" HP Spectre. This guide is written for the 15" HP Spectre.
Arthur Shi - 共有
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 51
今までの合計 8,733
