はじめに
This guide will instruct you on how to remove and replace the Wifi Adapter. Replacement of the wifi adapter may be necessary if the device cannot connect to the internet.
必要な工具と部品
Turn off and unplug the laptop.
Flip over the laptop so that the bottom backplate is exposed.
この手順で使用する道具:Tweezers$4.99
With the backplate removed, remove the four 3 mm screws securing the battery with a Phillips #1 screwdriver.
With the screws removed, disconnect the 3 wires connected to the battery.
もう少しです!
終わりに
