メインコンテンツにスキップ
HP Spectre x360 13-ac023dx Motherboard Replacement
必要な工具と部品
  1. HP Spectre x360 13-ac023dx Motherboard Replacement, Battery: 手順 1、 2の画像 1 HP Spectre x360 13-ac023dx Motherboard Replacement, Battery: 手順 1、 2の画像 2
    • Flip the laptop over so the model sticker faces the ceiling.
  2. HP Spectre x360 13-ac023dx Motherboard Replacement: 手順 2、 3の画像 1 HP Spectre x360 13-ac023dx Motherboard Replacement: 手順 2、 3の画像 2 HP Spectre x360 13-ac023dx Motherboard Replacement: 手順 2、 3の画像 3
    • Use a Torx #5 screwdriver to remove the six 3.5 mm screws holding the back cover to the laptop.
  3. HP Spectre x360 13-ac023dx Motherboard Replacement: 手順 3、 2の画像 1 HP Spectre x360 13-ac023dx Motherboard Replacement: 手順 3、 2の画像 2
    • Use the Phillips #000 screwdriver to remove the four 3.5 mm screws holding the battery.
    • After removing the screws, detach the battery wire from the mother board with the iFixit opening tool.
    • Then, carefully lift the battery off with the iFixit opening tool.
  4. HP Spectre x360 13-ac023dx Motherboard Replacement, Fan: 手順 4、 1の画像 1
    • Locate the Cooling Fan in the device.
  5. HP Spectre x360 13-ac023dx Motherboard Replacement: 手順 5、 2の画像 1 HP Spectre x360 13-ac023dx Motherboard Replacement: 手順 5、 2の画像 2
    • Use the Phillips #000 screwdriver to remove the 3mm screws holding the fan in place.
    • Remove the wires connecting to the motherboard, using the iFixit opening tool.
    • The iFixit Opening Tool is not required, but recommended
  6. HP Spectre x360 13-ac023dx Motherboard Replacement: 手順 6、 1の画像 1
    • Remove the Cooling Fan.
  7. HP Spectre x360 13-ac023dx Motherboard Replacement, WiFi Card: 手順 7、 1の画像 1
    • Locate the WiFi card.
  8. HP Spectre x360 13-ac023dx Motherboard Replacement: 手順 8、 1の画像 1
    • Use the Phillips #000 screwdriver to remove the screw holding the wifi card in place.
  9. HP Spectre x360 13-ac023dx Motherboard Replacement: 手順 9、 2の画像 1 HP Spectre x360 13-ac023dx Motherboard Replacement: 手順 9、 2の画像 2
    • Once the screw is removed, raise the WiFi card and slide it out from the motherboard.
  10. HP Spectre x360 13-ac023dx Motherboard Replacement, Motherboard: 手順 10、 1の画像 1
    • Ensure that all other components which were previously removed are not longer attached.
  11. HP Spectre x360 13-ac023dx Motherboard Replacement: 手順 11、 3の画像 1 HP Spectre x360 13-ac023dx Motherboard Replacement: 手順 11、 3の画像 2 HP Spectre x360 13-ac023dx Motherboard Replacement: 手順 11、 3の画像 3
    • Disconnect the wires which connect the motherboard to the rest of the components.
    • The black and red wire can be removed by pulling the wire upwards.
  12. HP Spectre x360 13-ac023dx Motherboard Replacement: 手順 12、 3の画像 1 HP Spectre x360 13-ac023dx Motherboard Replacement: 手順 12、 3の画像 2 HP Spectre x360 13-ac023dx Motherboard Replacement: 手順 12、 3の画像 3
    • Use the Phillips #000 screwdriver to remove the three 3.5 mm screws which keep the motherboard in place.
  13. HP Spectre x360 13-ac023dx Motherboard Replacement: 手順 13、 2の画像 1 HP Spectre x360 13-ac023dx Motherboard Replacement: 手順 13、 2の画像 2
    • Carefully lift and remove the motherboard.
終わりに
作成者
3人の作成者と共同で作成されました。
Jonathan
メンバー登録日: 10/21/19
486 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team S1-G6, Botvin Fall 2019 UMass Dartmouth, Team S1-G6, Botvin Fall 2019人のメンバー
UMASSD-BOTVIN-F19S1G6
3 メンバー
6のガイドは作成済み
コメント 1 件
Can I get ho spectre x360 motherboard to buy from your end?
Immanuel - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 12
過去 30 日: 48
今までの合計 3,412
