はじめに
The speakers are integral for playing audio in your device. If the audio is choppy or if the audio isn’t properly playing, you may need to replace the speakers in your device. Use this guide to replace the speakers in your laptop.
必要な工具と部品
Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
Orient the laptop the same way as the pictures. The battery is bordered in a red outline.
Remove the six 4 mm screws using a Phillips #000 screwdriver.
Remove four screws located on the bottom corners of speaker covers using the Phillips #00 screwdrivers.
Disconnect both 3-pin cables located on the edge of the computer.
Remove both speakers.
