メインコンテンツにスキップ
HP Spectre 13-4002dx Motherboard Replacement
必要な工具と部品
  1. HP Spectre 13-4002dx Motherboard Replacement, Bottom Case: 手順 1、 2の画像 1 HP Spectre 13-4002dx Motherboard Replacement, Bottom Case: 手順 1、 2の画像 2
    • Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
  2. HP Spectre 13-4002dx Motherboard Replacement: 手順 2、 2の画像 1 HP Spectre 13-4002dx Motherboard Replacement: 手順 2、 2の画像 2
    • Pry up one corner of the bottom case with a spudger.
    • Work the spudger around the edges, making your way towards the bottom of the laptop.
    • Remove the bottom case.
  3. HP Spectre 13-4002dx Motherboard Replacement, Battery: 手順 3、 3の画像 1 HP Spectre 13-4002dx Motherboard Replacement, Battery: 手順 3、 3の画像 2 HP Spectre 13-4002dx Motherboard Replacement, Battery: 手順 3、 3の画像 3
    • Orient the laptop the same way as the pictures. The battery is bordered in a red outline.
    • Remove the six 4 mm screws using a Phillips #000 screwdriver.
  4. HP Spectre 13-4002dx Motherboard Replacement: 手順 4、 3の画像 1 HP Spectre 13-4002dx Motherboard Replacement: 手順 4、 3の画像 2 HP Spectre 13-4002dx Motherboard Replacement: 手順 4、 3の画像 3
    • Do not disconnect the cable connector shown in the red box.
    • The speaker cable may be attached to the battery with black electrical tape. If so, remove the tape.
    • Move the cable clear of the battery.
  5. HP Spectre 13-4002dx Motherboard Replacement: 手順 5、 2の画像 1 HP Spectre 13-4002dx Motherboard Replacement: 手順 5、 2の画像 2
    この手順で使用する道具:
    購入する
    • Do not disconnect the cable connector located in the red box.
    • Use tweezers to remove the speaker cable from the groove attached to the battery.
    • Push the cable to the side so it does not get in the way of the battery removal.
  6. HP Spectre 13-4002dx Motherboard Replacement: 手順 6、 3の画像 1 HP Spectre 13-4002dx Motherboard Replacement: 手順 6、 3の画像 2 HP Spectre 13-4002dx Motherboard Replacement: 手順 6、 3の画像 3
    • Disconnect the battery cable connector by sliding it out of the socket.
    • Move the battery out of the way if you need more room to disconnect the power cable.
  7. HP Spectre 13-4002dx Motherboard Replacement: 手順 7、 1の画像 1
    • Carefully remove the battery.
  8. HP Spectre 13-4002dx Motherboard Replacement, Motherboard: 手順 8、 3の画像 1 HP Spectre 13-4002dx Motherboard Replacement, Motherboard: 手順 8、 3の画像 2 HP Spectre 13-4002dx Motherboard Replacement, Motherboard: 手順 8、 3の画像 3
    • Remove the black tape from the motherboard.
    • Remove five screws using the Phillips #00 screwdriver that holds the motherboard in place.
    • Disconnect five ribbon cables, three power cables, and two wifi antennas from the motherboard.
    • Gently lift the motherboard out of the computer. Be careful to not to disturb the CPU fan.
    • Do not bend the motherboard.
終わりに
作成者
1人の作成者と共同作成されました。
Dillon Wagers
メンバー登録日: 02/11/20
73 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 14
今までの合計 473
