はじめに
The laptop needs to be powered off before starting disassembly. The heat sink removes heat from the laptop. If you are experiencing overheating problems then you may need to replace the heat sink.
必要な工具と部品
Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
もう少しです!
終わりに
