メインコンテンツにスキップ
HP Spectre 13-4002dx Battery Replacement
必要な工具と部品
  1. HP Spectre 13-4002dx Battery Replacement, Bottom Case: 手順 1、 2の画像 1 HP Spectre 13-4002dx Battery Replacement, Bottom Case: 手順 1、 2の画像 2
    • Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
  2. HP Spectre 13-4002dx Battery Replacement: 手順 2、 2の画像 1 HP Spectre 13-4002dx Battery Replacement: 手順 2、 2の画像 2
    • Pry up one corner of the bottom case with a spudger.
    • Work the spudger around the edges, making your way towards the bottom of the laptop.
    • Remove the bottom case.
  3. HP Spectre 13-4002dx Battery Replacement, Battery: 手順 3、 3の画像 1 HP Spectre 13-4002dx Battery Replacement, Battery: 手順 3、 3の画像 2 HP Spectre 13-4002dx Battery Replacement, Battery: 手順 3、 3の画像 3
    • Orient the laptop the same way as the pictures. The battery is bordered in a red outline.
    • Remove the six 4 mm screws using a Phillips #000 screwdriver.
  4. HP Spectre 13-4002dx Battery Replacement: 手順 4、 3の画像 1 HP Spectre 13-4002dx Battery Replacement: 手順 4、 3の画像 2 HP Spectre 13-4002dx Battery Replacement: 手順 4、 3の画像 3
    • Do not disconnect the cable connector shown in the red box.
    • The speaker cable may be attached to the battery with black electrical tape. If so, remove the tape.
    • Move the cable clear of the battery.
  5. HP Spectre 13-4002dx Battery Replacement: 手順 5、 2の画像 1 HP Spectre 13-4002dx Battery Replacement: 手順 5、 2の画像 2
    この手順で使用する道具:
    購入する
    • Do not disconnect the cable connector located in the red box.
    • Use tweezers to remove the speaker cable from the groove attached to the battery.
    • Push the cable to the side so it does not get in the way of the battery removal.
  6. HP Spectre 13-4002dx Battery Replacement: 手順 6、 3の画像 1 HP Spectre 13-4002dx Battery Replacement: 手順 6、 3の画像 2 HP Spectre 13-4002dx Battery Replacement: 手順 6、 3の画像 3
    • Disconnect the battery cable connector by sliding it out of the socket.
    • Move the battery out of the way if you need more room to disconnect the power cable.
  7. HP Spectre 13-4002dx Battery Replacement: 手順 7、 1の画像 1
    • Carefully remove the battery.
終わりに
作成者
5人の作成者と共同で作成されました。
Cayce Stewart
メンバー登録日: 01/16/19
725 ポイント
6のガイドは作成済み
チーム
University of Alabama, Team S1-G4, Bedsole Spring 2019 University of Alabama, Team S1-G4, Bedsole Spring 2019人のメンバー
UA-BEDSOLE-S19S1G4
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 23
今までの合計 1,263
