はじめに
This guide will walk you through replacing the hard drive on a HP Pavilion Slim 410-017cb.
必要な工具と部品
After verifying the hard drive has failed (or is failing), remove the screw (T15) that holds the side cover on the case.
On this model, the hard drive is usually under the optical drive, screwed in below.
While uncommon, some systems which shipped with multiple drives (or selected CTO options) may have the drives and caddy installed here.
Before removing the DVD drive, disconnect the SATA data and power connections as shown.
For systems without the dual drive caddy mentioned in the previous step, you first need to remove the DVD drive. Push the green tabs shown to release it.
Remove the front panel from the system to reveal the screws that hold the drive cage NOTE: NO BETTER PICTURES ARE AVAILABLE, but this is held in with 3 clips which get unsnapped.
Remove the three screws (T15?) that secure the drive cage in the system.
Remove the four screws (T15) holding the old hard drive in the system.
Reverse disassembly to install the replacement drive
3 の人々がこのガイドを完成させました。
