はじめに
If you are having problems with your speakers, you should consider replacing them.
必要な工具と部品
Remove the orange and yellow ribbon cables.
detach the screws along the IO board
Remove the IO board and the speakers circuit. Note that they are held together.
The tablet has two speakers. Each speaker is located to both sides of the IO board.
Detach the speakers from the cables that connect the speakers and the IO board. You will find more details in step 5 and 6.
To remove the cables that connect the speakers and the IO board, apply a subtle pressure to pull the cable out.
Once you detach the speakers from the IO board, you should have three pieces as shown.
You are ready to replace the speakers.
ある他の人がこのガイドを完成しました。
