メインコンテンツにスキップ
HP Slate 8 Pro Motherboard Replacement
必要な工具と部品
  1. HP Slate 8 Pro Motherboard Replacement, Remove Back Panel: 手順 1、 2の画像 1 HP Slate 8 Pro Motherboard Replacement, Remove Back Panel: 手順 1、 2の画像 2
    • Secure the suction cup to the center of the device’s screen.
    • Begin to pull upwards with the suction cup. While pulling, start easing the plastic opening tool into the space between the screen and the device. This will gradually separate the screen from the plastic back panel.
  2. HP Slate 8 Pro Motherboard Replacement, Remove yellow cables: 手順 2、 2の画像 1 HP Slate 8 Pro Motherboard Replacement, Remove yellow cables: 手順 2、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use a spudger tool to release the black clips on the two connectors holding the flat, yellow cable in place.
    • Use the tweezers to pull the flat, yellow cable out of its connectors.
    • Use the tweezers to disconnect the battery connector from the circuit board.
    • Using the spudger tool again, pry up and release the connectors at the ends of the flat, orange cable.
    • Remove the flat, orange cable.
  3. HP Slate 8 Pro Motherboard Replacement, Remove Screws Around Battery: 手順 3、 1の画像 1
    • As shown, the battery is held in place by a total of 8 screws. Use the #00 Phillips screwdriver to remove all 8.
  4. HP Slate 8 Pro Motherboard Replacement, Lift Battery out of Device: 手順 4、 1の画像 1
    • Grasp the battery and remove it from the device.
    • Do not attempt to open or tamper with the battery. This could result in injury.
  5. HP Slate 8 Pro Motherboard Replacement, Motherboard: 手順 5、 1の画像 1
    この手順で使用する道具:
    購入する
    • Disconnect the five connectors.
    • With the zero insertion force connectors, be sure to flip up the tab to avoid damaging the connector.
    • Use tweezers to disconnect the three antenna connectors
  6. HP Slate 8 Pro Motherboard Replacement: 手順 6、 1の画像 1
    • Remove the four PH#00 2.4mm screws that hold in the motherboard in place.
  7. HP Slate 8 Pro Motherboard Replacement: 手順 7、 1の画像 1
    • Use tweezers and a spudger to remove the motherboard.
    • You may have to use a spudger to scrape off the adhesive holding the motherboard in place.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Andrew Hall
メンバー登録日: 05/23/16
322 ポイント
3のガイドは作成済み
チーム
IUPUI, Team 1-4, Renguette SU 2016 IUPUI, Team 1-4, Renguette SU 2016人のメンバー
IUPUI-RENGUETTE-SU16S1G4
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 505
