はじめに
This guide should be able to help you replace the microphone if not working properly on your HP device. By following these steps you should have it replaced or fixed in not time.
必要な工具と部品
Before opening your device, turn off the tablet. If you are unsure whether the tablet is off or in Hibernation, turn the tablet on, and then shut it down through the operating system.
Unplug your tablet from any power supply
Remove all external devices.
Remove back cover with plastic tools to avoid scratching the screen.
Disconnect the battery cable from the system board.
Use a little bit of pressure to remove the cable.
