はじめに
This guide is designed to help you out with changing the IO board. The IO board is used for charging the device, connecting the headphones, and being able to connect to the HDMI cable. If none of these are working you should consider replacing the board itself.
必要な工具と部品
Turn off the tablet. If you are unsure whether the tablet is off or in Hibernation, turn the tablet on, and then shut it down
Remove the back cover.
Remove the two Phillips PM1.5×4.0 screws that secure the I/O board to the display panel assembly.
ある他の人がこのガイドを完成しました。
