必要な工具と部品
Turn off the tablet and disconnect the power and all external devices from the tablet.
Position the tablet with the display panel down and the right side toward you.
Carefully insert a plastic opening tool between the tablet cover and display panel assembly, separating the two components. The first insertion point should be between the power button and the volume buttons.
Disconnect the battery cables from the system board by desoldering them. See iFixit guide on how to solder.
Use tweezers to remove the black foam stickers from the front facing camera to expose the wiring.
Use the tweezers to remove the black foam stickers from the rear facing camera to expose the wiring.
Remove the two grey wires on the left and the four multicolored wires on the right by desoldering them. See iFixit guide on how to solder.
Remove the screen by holding the tablet in one hand with the back of the LCD screen facing up. Slowly rotate the tablet so the screen falls into your other hand.
3 の人々がこのガイドを完成させました。
