メインコンテンツにスキップ
HP Slate 7 Plus 4200US Front Facing Webcamera Replacement
必要な工具と部品
  1. HP Slate 7 Plus 4200US Front Facing Webcamera Replacement, Tablet Cover: 手順 1、 1の画像 1
    • Turn off the tablet and disconnect the power and all external devices from the tablet.
    • Position the tablet with the display panel down and the right side toward you.
    • Carefully insert a plastic opening tool between the tablet cover and display panel assembly, separating the two components. The first insertion point should be between the power button and the volume buttons.
  2. HP Slate 7 Plus 4200US Front Facing Webcamera Replacement: 手順 2、 2の画像 1 HP Slate 7 Plus 4200US Front Facing Webcamera Replacement: 手順 2、 2の画像 2
    • Slide the tool around the perimeter of the tablet until the edge of the cover is completely separated from the display panel assembly.
  3. HP Slate 7 Plus 4200US Front Facing Webcamera Replacement: 手順 3、 3の画像 1 HP Slate 7 Plus 4200US Front Facing Webcamera Replacement: 手順 3、 3の画像 2 HP Slate 7 Plus 4200US Front Facing Webcamera Replacement: 手順 3、 3の画像 3
    • Pry open the back cover to take it off.
  4. HP Slate 7 Plus 4200US Front Facing Webcamera Replacement, Battery: 手順 4、 3の画像 1 HP Slate 7 Plus 4200US Front Facing Webcamera Replacement, Battery: 手順 4、 3の画像 2 HP Slate 7 Plus 4200US Front Facing Webcamera Replacement, Battery: 手順 4、 3の画像 3
    • Disconnect the battery cables from the system board by desoldering them. See iFixit guide on how to solder.
    • The battery cables are soldered to the system in the following sequence, top to bottom: red, blue, green, yellow, black.
  5. HP Slate 7 Plus 4200US Front Facing Webcamera Replacement: 手順 5、 3の画像 1 HP Slate 7 Plus 4200US Front Facing Webcamera Replacement: 手順 5、 3の画像 2 HP Slate 7 Plus 4200US Front Facing Webcamera Replacement: 手順 5、 3の画像 3
    • Insert a nylon spudger between the battery and the display panel assembly. Carefully pry the battery up and remove it from its place.
    • The battery is attached to the display panel assembly with double-sided adhesive. Make sure to firmly pull the battery.
    • The regular black nylon spudger should be used whenever possible, especially around batteries.
  6. HP Slate 7 Plus 4200US Front Facing Webcamera Replacement, Front Facing Webcamera: 手順 6、 2の画像 1 HP Slate 7 Plus 4200US Front Facing Webcamera Replacement, Front Facing Webcamera: 手順 6、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use tweezers to remove the black foam stickers from the front facing camera to expose the wiring.
  7. HP Slate 7 Plus 4200US Front Facing Webcamera Replacement: 手順 7、 2の画像 1 HP Slate 7 Plus 4200US Front Facing Webcamera Replacement: 手順 7、 2の画像 2
    • Lift the camera out from system board and firmly pull the wire out from the connector.
終わりに
作成者
3人の作成者と共同で作成されました。
Jessica Andrade
メンバー登録日: 10/04/16
860 ポイント
7のガイドは作成済み
チーム
USF Tampa, Team 3-1, Sullivan Fall 2016 USF Tampa, Team 3-1, Sullivan Fall 2016人のメンバー
USFT-SULLIVAN-F16S3G1
3 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 127
