必要な工具と部品
Turn off the tablet and disconnect the power and all external devices from the tablet.
Position the tablet with the display panel down and the right side toward you.
Carefully insert a plastic opening tool between the tablet cover and display panel assembly, separating the two components. The first insertion point should be between the power button and the volume buttons.
Disconnect the battery cables from the system board by desoldering them. See iFixit guide on how to solder.
ある他の人がこのガイドを完成しました。
