With the pointed end of the spudger, remove the thin metal band.
It is easiest to remove the metal band through the headphone opening.
Using the flat end of the spudger, pry back the rear plastic cover.
As you work your way around the edge, several "pop" noises will be made. These noises are caused by the plastic clips coming undone.
Using the pointed end of the spudger, push both sides of the speaker wire connector out of its base.
Push the same amount on both sides of the connector to avoid jamming or twisting its metal pins.
Do not yank or pull on the speaker wires, since they are fragile. Only push on the white connector.
Using the flat end of the spudger, lift up the black panel covering the charging port connector.
Gently slide the charging port ribbon out from its housing.
It may be easier to use the pointed end of the spudger than your fingers.
Using the #00 Phillips Head screwdriver, remove the 5 screws holding the battery in place.
The four 1.75mm x 3mm silver Phillips Head screws circled in red are interchangeable.
The black 1.75mm x 4mm Phillips Head screw must go back to the same spot during reassembly.
Disconnect the LCD screen ribbon by lifting up the black panel with the flat end of a spudger and sliding the gold strip out.
When reconnecting the LCD connector ribbon, make sure that it's pushed in all the way. If it isn't, there will be horizontal lines when you power the tablet on.
Using your hand, lift up the silver tape from the copper plate.
Lift the motherboard out of the device.
You may need to wiggle and work the motherboard to get it released from the device
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
1つの手順
全ガイド
小サイズ - 600px
中サイズ - 800px
大サイズ - 1200px
プレビュー
