はじめに
The front screen of your HP tablet is the toughest thing to replace - you need to go through the rest of the tablet first, starting at the back and working your way forward. The same goes for the volume buttons. In this guide, you will be removing the following:
- Back Cover
- Battery
- Charging Port
- Speaker Unit
- Motherboard
- Front LCD Screen
Prepare your required tools, a new battery for your tablet, and set aside about 30 to 40 minutes to delve into the inner workings of your HP Slate.
必要な工具と部品
Begin your replacement by using a T3 or T4 Torx screwdriver.
Remove the two 1.4mm x 3mm Torx Head screws at the top of the device.
To free the speaker assembly, you will need a #00 Phillips Head screwdriver.
Remove the two 1.75mm x 3mm Phillips Head screws from the speaker assembly.
Disconnect the LCD screen ribbon by lifting up the black panel with the flat end of a spudger and sliding the gold strip out.
Remove the metal band surrounding the device by lifting it up out of the placement pins. Begin at one end and work your way around.
13 の人々がこのガイドを完成させました。
