メインコンテンツにスキップ
HP Slate 7 4601 Charging Port Replacement
必要な工具と部品
  1. HP Slate 7 4601 Charging Port Replacement, Battery: 手順 1、 2の画像 1 HP Slate 7 4601 Charging Port Replacement, Battery: 手順 1、 2の画像 2
    • Begin your replacement by using a T3 or T4 Torx screwdriver.
    • Remove the two 1.4mm x 3mm Torx Head screws at the top of the device.
  2. HP Slate 7 4601 Charging Port Replacement: 手順 2、 2の画像 1 HP Slate 7 4601 Charging Port Replacement: 手順 2、 2の画像 2
    • With the pointed end of the spudger, remove the thin metal band.
    • It is easiest to remove the metal band through the headphone opening.
  3. HP Slate 7 4601 Charging Port Replacement: 手順 3、 2の画像 1 HP Slate 7 4601 Charging Port Replacement: 手順 3、 2の画像 2
    • Using the flat end of the spudger, pry back the rear plastic cover.
    • As you work your way around the edge, several "pop" noises will be made. These noises are caused by the plastic clips coming undone.
  4. HP Slate 7 4601 Charging Port Replacement: 手順 4、 1の画像 1
    • Remove the rear cover.
  5. HP Slate 7 4601 Charging Port Replacement: 手順 5、 1の画像 1
    • Locate and remove the yellow tape covering the red and white speaker wires.
  6. HP Slate 7 4601 Charging Port Replacement: 手順 6、 2の画像 1 HP Slate 7 4601 Charging Port Replacement: 手順 6、 2の画像 2
    • Using the pointed end of the spudger, push both sides of the speaker wire connector out of its base.
    • Push the same amount on both sides of the connector to avoid jamming or twisting its metal pins.
    • Do not yank or pull on the speaker wires, since they are fragile. Only push on the white connector.
  7. HP Slate 7 4601 Charging Port Replacement: 手順 7、 1の画像 1
    • Gently pull back the foil covering the gold charging port ribbon.
  8. HP Slate 7 4601 Charging Port Replacement: 手順 8、 2の画像 1 HP Slate 7 4601 Charging Port Replacement: 手順 8、 2の画像 2
    • Using the flat end of the spudger, lift up the black panel covering the charging port connector.
    • Gently slide the charging port ribbon out from its housing.
    • It may be easier to use the pointed end of the spudger than your fingers.
  9. HP Slate 7 4601 Charging Port Replacement: 手順 9、 1の画像 1
    • Lift gold charging strip away from the battery.
  10. HP Slate 7 4601 Charging Port Replacement: 手順 10、 2の画像 1 HP Slate 7 4601 Charging Port Replacement: 手順 10、 2の画像 2
    • Push the white battery connector out of its housing using the pointed end of the spudger.
  11. HP Slate 7 4601 Charging Port Replacement: 手順 11、 1の画像 1
    • Using the #00 Phillips Head screwdriver, remove the 5 screws holding the battery in place.
    • The four 1.75mm x 3mm silver Phillips Head screws circled in red are interchangeable.
    • The black 1.75mm x 4mm Phillips Head screw must go back to the same spot during reassembly.
  12. HP Slate 7 4601 Charging Port Replacement: 手順 12、 1の画像 1
    • Lift battery out of its place and set aside.
  13. HP Slate 7 4601 Charging Port Replacement, Charging Port: 手順 13、 2の画像 1 HP Slate 7 4601 Charging Port Replacement, Charging Port: 手順 13、 2の画像 2
    • To free the speaker assembly, you will need a #00 Phillips Head screwdriver.
    • Remove the two 1.75mm x 3mm Phillips Head screws from the speaker assembly.
  14. HP Slate 7 4601 Charging Port Replacement: 手順 14、 2の画像 1 HP Slate 7 4601 Charging Port Replacement: 手順 14、 2の画像 2
    • Pull back the foil overlapping the charging port to reveal another 1.75mm x 3mm Phillips Head screw.
    • Remove the screw with a #00 Phillips Head screwdriver.
  15. HP Slate 7 4601 Charging Port Replacement: 手順 15、 1の画像 1
    • Lift the charging port and set it aside.
終わりに
34 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Raj Parekh
メンバー登録日: 04/14/14
535 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 13-30, Maness Spring 2014 Cal Poly, Team 13-30, Maness Spring 2014人のメンバー
CPSU-MANESS-S14S13G30
3 メンバー
8のガイドは作成済み
15 件のコメント
where do you get the replacement parts for charging port
Scott Winstone - 返信
Since HP does not supply the replacement ribbon, or many other parts for that matter, it is easiest to search on eBay and/or Craigslist for the parts needed. I found that the UK version of Amazon and eBay offer the best availability for such parts.
Zachary -
I had to stop at Step 1. The T4 Torx screwdriver is too big.
stevwatsn - 返信
My apologies for the incorrect sizing of the Torx driver; please use a T3 sized driver, as it is the next size down from the T4.
Zachary -
do you have a product number for the charger strip?
Courtney - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 14
今までの合計 47,872
