はじめに
After many times of attempting to recharge the battery with no success, it may be time for your Slate's battery to be replaced. This repair guide is the primary step for all future repairs on your HP Slate, and is a basic process to master. In this guide, you will be removing the following:
- Back Cover
- Battery
Prepare your required tools, a new battery for your tablet, and set aside about 10 to 15 minutes to delve into the inner workings of your HP Slate.
必要な工具と部品
Begin your replacement by using a T3 or T4 Torx screwdriver.
Remove the two 1.4mm x 3mm Torx Head screws at the top of the device.
With the pointed end of the spudger, remove the thin metal band.
Using the flat end of the spudger, pry back the rear plastic cover.
This is basically how I opened my HP 10 Plus 2201. "Using the flat end of the spudger, pry back (apart) the rear plastic cover from tablet.
RB Richter - 返信
Locate and remove the yellow tape covering the red and white speaker wires.
The inside of my HP 10 Plus 2210 looks similar but not exactly as this illustration
RB Richter - 返信
The battery connections weren't the plug in type. The three battery battery wires (red, white, & black) were soldered into place,
RB Richter - 返信
Using the pointed end of the spudger, push both sides of the speaker wire connector out of its base.
Do not pull on wires. Never force anything.
RB Richter - 返信
note the route of the speaker cables round the battery
Gently pull back the foil covering the gold charging port ribbon.
Hpcom Support Helps HP Printer users to download and install All Hp Printers drivers. We also provide all possible solutions to fix hp Printer problems. If you face any issue in install Hp printer driver or having other problems with the hp Printer, you can follow our 100 % working solutions. In case you can’t able to continue printing, then feel free to contact us. We are happy to serve you.
18 の人々がこのガイドを完成させました。
3 件のコメント
Buenas tardes, como están? Consulta, la batería se puede reemplazar por otra genérica, existe algún repuesto?
Thanx for this amazing demo steps. Sir i need battery of this tab, coz i cant find this battery anywhere then someone told me to go online purchase it wil you so i decided to go online n finally i found ur page so plz arrange me the battery of this tab. My HP Slate 7 battery is not charging . I m from pakistan n my email is aasifbrothers79@gmail.com. Sir i m looking forward for ur kind reply .Thanx
Regards, Asif Sultan
where do i buy the battery in india… there is a site Maxbhi, I ordered the battery, they never send the battery neither returned the money…
On the HP 10 Plus 2201 there are no head screws. I used the spudger to 'carefully' separate the case. There are little snaps on the inside of case that will separate with little pressure on spudger.
RB Richter - 返信
I used these directions to replace HP Plus 10 2201 battery. I bypassed speaker installation.
RB Richter - 返信
