はじめに
If your HP Probook x360 11 G5 EE laptop does not charge unless the adapter is positioned in a specific position, the charging port may need to be replaced. The charging port is important because it charges the battery to supply the power to your laptop.
必要な工具と部品
Remove the 4.1 mm screws with a T5 Torx screwdriver.
Remove the 4.1 mm screws using a JIS #0 screwdriver.
Remove the single 3 mm screw from the charging port using a T5 Torx screwdriver.
ある他の人がこのガイドを完成しました。
コメント 1 件
Hi!! I have the same model of notebook with 64 giga emmc. Is it possible installing an ssd or an hdd?
