メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP ProBook x360 11 G3 EE Keyboard Replacement
必要な工具と部品
  1. HP ProBook x360 11 G3 EE Keyboard Replacement, Keyboard: 手順 1、 3の画像 1 HP ProBook x360 11 G3 EE Keyboard Replacement, Keyboard: 手順 1、 3の画像 2 HP ProBook x360 11 G3 EE Keyboard Replacement, Keyboard: 手順 1、 3の画像 3
    • To begin, flip your laptop to where the base is facing upwards.
    • Grab your TR9 screwdriver, and take the four screws out that are in all four corners of the base. The bottom two are 5.2 mm Torx Security screws and the top two are 9 mm Torx Security screws.
    • Note: On the top right and the top left screws, you may have to get an opening pick and gently hold the two 9 mm Torx Security screws up to get them out, because of the magnetic pull. (see last photo)
    • Also, with the same TR9 screwdriver, take out the two 5.2 mm Torx Security screws directly between the bottom left and bottom right screws (aligned in a row of 4).
    • Grab your JIS #0 (J0) screwdriver, and take out the remaining two 6.7 mm Japanese Industrial screws located in the middle of the base directly across from each other.
  2. HP ProBook x360 11 G3 EE Keyboard Replacement: 手順 2、 3の画像 1 HP ProBook x360 11 G3 EE Keyboard Replacement: 手順 2、 3の画像 2 HP ProBook x360 11 G3 EE Keyboard Replacement: 手順 2、 3の画像 3
    • Flip your laptop upright (facing towards you), to where the base is now on a flat surface.
    • Open your laptop.
    • Begin to pry the corners of the keyboard deck with an opening pick.
  3. HP ProBook x360 11 G3 EE Keyboard Replacement: 手順 3、 3の画像 1 HP ProBook x360 11 G3 EE Keyboard Replacement: 手順 3、 3の画像 2 HP ProBook x360 11 G3 EE Keyboard Replacement: 手順 3、 3の画像 3
    • Use an opening tool to pry around the perimeter of the keyboard deck until it gently pops out of place.
  4. HP ProBook x360 11 G3 EE Keyboard Replacement: 手順 4、 1の画像 1
    • Lift the keyboard deck to reveal two ribbon cables.
  5. HP ProBook x360 11 G3 EE Keyboard Replacement: 手順 5、 3の画像 1 HP ProBook x360 11 G3 EE Keyboard Replacement: 手順 5、 3の画像 2 HP ProBook x360 11 G3 EE Keyboard Replacement: 手順 5、 3の画像 3
    • Disconnect the two ribbon cables by lifting the tiny plastic flaps upwards to release them.
  6. HP ProBook x360 11 G3 EE Keyboard Replacement: 手順 6、 1の画像 1
    • Remove the keyboard deck from the base of the laptop.
終わりに
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
作成者
1人の作成者と共同作成されました。
cambree brown
メンバー登録日: 09/25/25
613 ポイント
4のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 8
今までの合計 86
