メインコンテンツにスキップ
HP ProBook 650 G2 Battery Replacement
必要な工具と部品
  1. HP ProBook 650 G2 Battery Replacement, Remove the case screws: 手順 1、 1の画像 1
    • There are 8 case screws that all use a PH1 bit
  2. HP ProBook 650 G2 Battery Replacement, Pry open the case: 手順 2、 3の画像 1 HP ProBook 650 G2 Battery Replacement, Pry open the case: 手順 2、 3の画像 2 HP ProBook 650 G2 Battery Replacement, Pry open the case: 手順 2、 3の画像 3
    • Start at the back near the hinge with a pry tool
    • Work your way around to the front using enough pressure to release the plastic clips
    • Once you get near the opposite corner it should release to a point where you can use your hand to pull it open
  3. HP ProBook 650 G2 Battery Replacement, Remove the battery: 手順 3、 2の画像 1 HP ProBook 650 G2 Battery Replacement, Remove the battery: 手順 3、 2の画像 2
    • There are 7 captive screws (on the original HP battery) around the edge of the battery that use a PH1 bit
    • Once the screws are removed you can use the tab nearest the front center of the laptop to lift the battery up and out
  4. HP ProBook 650 G2 Battery Replacement, (Optional) Remove captive screws: 手順 4、 1の画像 1
    • If your new battery did not come with the captive screws you can unscrew them from the old battery by applying pressure under the screw while unscrewing them so you can transfer them to the new battery
終わりに
作成者
2人の作成者と共同で作成されました。
The Bearded IT Guy
メンバー登録日: 08/27/23
109 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 26
今までの合計 218
