メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP ProBook 640 G5 WLAN Module Replacement
必要な工具と部品
  1. HP ProBook 640 G5 WLAN Module Replacement, Back Cover: 手順 1、 1の画像 1
    • Always make sure the HP ProBook 640 G5 is completely powered off and unplugged before beginning this repair. Attempting to open the laptop while it has power may cause electrical damage or personal injury.
    • Shut down the HP ProBook 640 G5 completely.
    • Disconnect the power adapter and all connected peripherals.
    • Press and hold the power button for 5 seconds to discharge remaining electricity.
    FixBotに聞いてみる
  2. HP ProBook 640 G5 WLAN Module Replacement: 手順 2、 1の画像 1
    • Flip the laptop over so the bottom is facing up.
    • Loosen eight silver 6mm screws using a Phillips #0 screwdriver.
    • These screws are captive, so they will loosen but remain attached to the cover.
    • Remove two black 6mm screws using a TR7 Torx screwdriver.
    • Insert a plastic opening tool into the seam and gently pry around the edges.
    • Lift the bottom cover away from the laptop.
    FixBotに聞いてみる
  3. HP ProBook 640 G5 WLAN Module Replacement, WLAN Module: 手順 3、 2の画像 1 HP ProBook 640 G5 WLAN Module Replacement, WLAN Module: 手順 3、 2の画像 2
    • When replacing the WLAN module, avoid touching the gold contacts and black chips. Handle the stick only by its outer edges or plastic/metal shielding. Touching the chips or gold contacts can introduce static electricity or oil from your fingers, potentially causing damage or poor connectivity.
    • Locate the WLAN module.
    • You can identify it by its small size (usually M.2 2230) or labels such as WLAN, Wi-Fi, or M.2 nearby.
    • Remove the single screw holding the WLAN card down.
    FixBotに聞いてみる
  4. HP ProBook 640 G5 WLAN Module Replacement: 手順 4、 1の画像 1
    • The card will pop up at an angle (about 25–30 degrees).
    • Slide it straight out of the socket.
    FixBotに聞いてみる
終わりに
作成者
2人の作成者と共同で作成されました。
Eric Olivarez
メンバー登録日: 02/23/26
449 ポイント
4のガイドは作成済み
チーム
Austin Community College, Team 1-2, Anderson Spring 2026 Austin Community College, Team 1-2, Anderson Spring 2026人のメンバー
AUSTINCC-ANDERSON-S26S1G2
3 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 22
今までの合計 40
