メインコンテンツにスキップ
HP ProBook 455 G1 DVD/CD Drive Replacement
必要な工具と部品
  1. HP ProBook 455 G1 DVD/CD Drive  Replacement, Battery: 手順 1、 1の画像 1
    • Turn the computer upside down on a flat side, so that you are seeing the underside of the laptop.
    • Before removing the battery, make sure that the computer is turned off and that the power cord is not plugged into the computer.
  2. HP ProBook 455 G1 DVD/CD Drive  Replacement: 手順 2、 1の画像 1
    • Slide the two battery release latches towards the center of the laptop to release the battery.
  3. HP ProBook 455 G1 DVD/CD Drive  Replacement: 手順 3、 2の画像 1 HP ProBook 455 G1 DVD/CD Drive  Replacement: 手順 3、 2の画像 2
    • Tilt the battery upward.
    • Remove it from the laptop.
  4. HP ProBook 455 G1 DVD/CD Drive  Replacement, Service Panel: 手順 4、 1の画像 1
    • Slide the two release latches that were mentioned in the battery removal process to release the service panel.
  5. HP ProBook 455 G1 DVD/CD Drive  Replacement: 手順 5、 2の画像 1 HP ProBook 455 G1 DVD/CD Drive  Replacement: 手順 5、 2の画像 2
    • Slide the service panel toward you using your thumbs.
    • Lift it to remove the panel and reveal inner components of the computer.
  6. HP ProBook 455 G1 DVD/CD Drive  Replacement, DVD/CD Drive: 手順 6、 2の画像 1 HP ProBook 455 G1 DVD/CD Drive  Replacement, DVD/CD Drive: 手順 6、 2の画像 2
    • Using a Phillips P0 Screwdriver, remove the 6 millimeter screw that secures the DVD/CD drive to the computer.
    • It will be located in the upper left section of the computer, housed in a small square hole in the computer frame.
    • The Phillips head screwdriver is the screwdriver with a "+" shaped tip. P0 refers to the name/size of this particular Phillips head screwdriver.
  7. HP ProBook 455 G1 DVD/CD Drive  Replacement: 手順 7、 1の画像 1
    • Using the screwdriver, gently push the silver tab that the screw secured to the left to release the DVD/CD drive from the computer.
  8. HP ProBook 455 G1 DVD/CD Drive  Replacement: 手順 8、 1の画像 1
    • The DVD/CD drive will be extended from the side of the laptop. Slowly remove it from the computer.
終わりに
作成者
3人の作成者と共同で作成されました。
Jennifer Sexton
メンバー登録日: 03/18/18
649 ポイント
4のガイドは作成済み
チーム
Baylor, Team S5-G1, Williams Spring 2018 Baylor, Team S5-G1, Williams Spring 2018人のメンバー
BU-WILLIAMS-S18S5G1
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 5
過去 30 日: 22
今までの合計 933
