メインコンテンツにスキップ
HP ProBook 4540s WLAN Module Replacement
必要な工具と部品
  1. HP ProBook 4540s WLAN Module Replacement, Battery: 手順 1、 1の画像 1
    • Make sure the computer is shut off and the power cord is unplugged from the AC outlet.
    • Slide the two release latches on either side of the battery.
    • Gently tilt the battery upward and remove it from its socket.
  2. HP ProBook 4540s WLAN Module Replacement, Bottom Door: 手順 2、 1の画像 1
    • Turn the computer so the bottom is facing towards you.
    • Remove the one 3.0 mm Phillips PM2.0x3.0 security screw.
    • The security screw is an optional feature and isn't required to hold the backing if there is not one screwed in place.
    • Slide the release latches then pull the door towards you. Lift the door away to completely remove it.
  3. HP ProBook 4540s WLAN Module Replacement, WLAN Module: 手順 3、 2の画像 1 HP ProBook 4540s WLAN Module Replacement, WLAN Module: 手順 3、 2の画像 2
    • Disconnect the antenna cables from their terminals in the WLAN module.
    • One cable is attached to the Auxiliary ("Aux") terminal, represented with a blue wire. The other cable is connected to the Main terminal which is usually represented with a red wire. These wires can be seen in little windows beside the component.
  4. HP ProBook 4540s WLAN Module Replacement: 手順 4、 2の画像 1 HP ProBook 4540s WLAN Module Replacement: 手順 4、 2の画像 2
    • Unscrew two 3.0 mm Phillips PM2.0x3.0 screw securing the module to the computer.
    • The edge of the module that is opposite of the slot is risen away from the computer.
    • Gently lift and remove the module.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Amber Schindler
メンバー登録日: 10/26/16
1,027 ポイント
6のガイドは作成済み
チーム
UW Tacoma, Team 1-5, Rose Fall 2016 UW Tacoma, Team 1-5, Rose Fall 2016人のメンバー
UWT-ROSE-F16S1G5
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 25
今までの合計 1,880
