メインコンテンツにスキップ
HP ProBook 4540s Keyboard Replacement
必要な工具と部品
  1. HP ProBook 4540s Keyboard Replacement, Battery: 手順 1、 1の画像 1
    • Make sure the computer is shut off and the power cord is unplugged from the AC outlet.
    • Slide the two release latches on either side of the battery.
    • Gently tilt the battery upward and remove it from its socket.
  2. HP ProBook 4540s Keyboard Replacement, Bottom Door: 手順 2、 1の画像 1
    • Turn the computer so the bottom is facing towards you.
    • Remove the one 3.0 mm Phillips PM2.0x3.0 security screw.
    • The security screw is an optional feature and isn't required to hold the backing if there is not one screwed in place.
    • Slide the release latches then pull the door towards you. Lift the door away to completely remove it.
  3. HP ProBook 4540s Keyboard Replacement, Keyboard: 手順 3、 1の画像 1
    • Remove four 6.0 mm Phillips PM2.5x6.0 screws.
  4. HP ProBook 4540s Keyboard Replacement: 手順 4、 1の画像 1
    • Turn the computer over and position it right-side up in order and open the computer as far as possible.
  5. HP ProBook 4540s Keyboard Replacement: 手順 5、 1の画像 1
    • Move the keyboard in a downward fashion towards the palm rest.
  6. HP ProBook 4540s Keyboard Replacement: 手順 6、 1の画像 1
    • Lift the top of the keyboard at an angle and then gently pull it up and away from the palm rest.
    • Only pull the keyboard up enough to release it. The cable beneath the keyboard will still be attached to the system board.
  7. HP ProBook 4540s Keyboard Replacement: 手順 7、 1の画像 1
    • Disconnect the keyboard cable by lifting the latch at the center of the system board.
    • Completely remove the keyboard.
終わりに
15 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Amber Schindler
メンバー登録日: 10/26/16
1,027 ポイント
6のガイドは作成済み
チーム
UW Tacoma, Team 1-5, Rose Fall 2016 UW Tacoma, Team 1-5, Rose Fall 2016人のメンバー
UWT-ROSE-F16S1G5
4 メンバー
6のガイドは作成済み
2 件のコメント
Precise and clear guide. Great Work!!!
Mario Mutale - 返信
Easy to follow and a great help to get the job done. Thanks
d1211109 - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 29
今までの合計 7,103
