メインコンテンツにスキップ
HP ProBook 450 G4 Speaker Replacement
必要な工具と部品
  1. HP ProBook 450 G4 Speaker Replacement, Hard Drive: 手順 1、 2の画像 1 HP ProBook 450 G4 Speaker Replacement, Hard Drive: 手順 1、 2の画像 2
    • Power your laptop off.
    • Flip the laptop over.
    • Orient the laptop so the two vents on the bottom face upward and are further away from you.
  2. HP ProBook 450 G4 Speaker Replacement: 手順 2、 3の画像 1 HP ProBook 450 G4 Speaker Replacement: 手順 2、 3の画像 2 HP ProBook 450 G4 Speaker Replacement: 手順 2、 3の画像 3
    • Use the Phillips #0 screwdriver to remove the 6.8 mm screw that secures the vent panel to the laptop.
    • Use the spudger to separate the vent panel from the laptop.
    • Slide the vent panel off the backside of the laptop.
  3. HP ProBook 450 G4 Speaker Replacement: 手順 3、 2の画像 1 HP ProBook 450 G4 Speaker Replacement: 手順 3、 2の画像 2
    • Use the Phillips #0 screwdriver to remove the black 3.2mm screw that secures the hard drive to the left side of the laptop.
  4. HP ProBook 450 G4 Speaker Replacement: 手順 4、 2の画像 1 HP ProBook 450 G4 Speaker Replacement: 手順 4、 2の画像 2
    • Use the spudger to lift the left side of the hard drive up.
    • Pull the hard drive diagonally to the left to release the hard drive from the laptop.
  5. HP ProBook 450 G4 Speaker Replacement, Keyboard: 手順 5、 3の画像 1 HP ProBook 450 G4 Speaker Replacement, Keyboard: 手順 5、 3の画像 2 HP ProBook 450 G4 Speaker Replacement, Keyboard: 手順 5、 3の画像 3
    • Remove the 6.6mm T8 Torx screw located below where the hard drive used to be.
    • Remove the 6.6mm T8 Torx screw located below and to the left of the circular, silver and black fan.
  6. HP ProBook 450 G4 Speaker Replacement: 手順 6、 3の画像 1 HP ProBook 450 G4 Speaker Replacement: 手順 6、 3の画像 2 HP ProBook 450 G4 Speaker Replacement: 手順 6、 3の画像 3
    • Use the spudger to press down on the two black tabs that are underneath where the hard drive used to be.
    • Apply pressure to the black tabs until they release and pop out.
  7. HP ProBook 450 G4 Speaker Replacement: 手順 7、 3の画像 1 HP ProBook 450 G4 Speaker Replacement: 手順 7、 3の画像 2 HP ProBook 450 G4 Speaker Replacement: 手順 7、 3の画像 3
    • Orient the laptop so the keyboard is facing upwards and towards you.
    • Insert the spudger in between the edge of the keyboard and the computer frame.
    • Slide the spudger around the edge of the keyboard until the keyboard is loose.
    • Gently pull the keyboard away from the body of the laptop.
    • Do not pull the keyboard all the way off because there is still a connector cable underneath that needs to be disconnected.
  8. HP ProBook 450 G4 Speaker Replacement: 手順 8、 2の画像 1 HP ProBook 450 G4 Speaker Replacement: 手順 8、 2の画像 2
    • Use a spudger to gently lift up the black locking bar on the keyboard connector.
    • Slide the keyboard ribbon out of the connector.
    • Remove the keyboard.
    • To re-attach the keyboard ribbon, slide it into the connector and swing the locking bar down.
  9. HP ProBook 450 G4 Speaker Replacement, Battery: 手順 9、 2の画像 1 HP ProBook 450 G4 Speaker Replacement, Battery: 手順 9、 2の画像 2
    • Flip the laptop back over.
    • Remove the eight 6.8mm T8 Torx screws on the backside of the laptop.
  10. HP ProBook 450 G4 Speaker Replacement: 手順 10、 2の画像 1 HP ProBook 450 G4 Speaker Replacement: 手順 10、 2の画像 2
    • Use a Phillips #0 screwdriver to remove the three 6.6mm screws from the upper left corner of the laptop.
  11. HP ProBook 450 G4 Speaker Replacement: 手順 11、 2の画像 1 HP ProBook 450 G4 Speaker Replacement: 手順 11、 2の画像 2
    • Use the spudger to slide the disk drive out of the laptop.
    • Use the Phillips #0 screwdriver to remove the two 3.2mm screws that are underneath where the disk drive previously was.
  12. HP ProBook 450 G4 Speaker Replacement: 手順 12、 3の画像 1 HP ProBook 450 G4 Speaker Replacement: 手順 12、 3の画像 2 HP ProBook 450 G4 Speaker Replacement: 手順 12、 3の画像 3
    • Use a Phillips #0 screwdriver to remove the two 6.6mm screws.
  13. HP ProBook 450 G4 Speaker Replacement: 手順 13、 2の画像 1 HP ProBook 450 G4 Speaker Replacement: 手順 13、 2の画像 2
    • Flip the laptop back over so it is facing upwards.
    • Remove the six 6.6mm T8 Torx screws underneath where the keyboard used to be.
  14. HP ProBook 450 G4 Speaker Replacement: 手順 14、 3の画像 1 HP ProBook 450 G4 Speaker Replacement: 手順 14、 3の画像 2 HP ProBook 450 G4 Speaker Replacement: 手順 14、 3の画像 3
    • Use the spudger to disconnect the nine cable connectors that secure the top case of the laptop to the body of the laptop.
    • Be extra careful while disconnecting the cable connectors because they can tear easily.
  15. HP ProBook 450 G4 Speaker Replacement: 手順 15、 2の画像 1 HP ProBook 450 G4 Speaker Replacement: 手順 15、 2の画像 2
    • Insert the spudger in between the top case of the laptop and its outer frame.
    • Slide the spudger around the edge of the laptop until the top case comes off.
    • Remove the top case.
  16. HP ProBook 450 G4 Speaker Replacement: 手順 16、 2の画像 1 HP ProBook 450 G4 Speaker Replacement: 手順 16、 2の画像 2
    • Insert the opening tool underneath the left side of the battery to remove it from the laptop.
  17. HP ProBook 450 G4 Speaker Replacement, Speaker: 手順 17、 2の画像 1 HP ProBook 450 G4 Speaker Replacement, Speaker: 手順 17、 2の画像 2
    • Orient the top case of the laptop so that the internal parts are facing upwards and green rectangular object is closer to you.
    • Identify the two speakers at the top.
  18. HP ProBook 450 G4 Speaker Replacement: 手順 18、 3の画像 1 HP ProBook 450 G4 Speaker Replacement: 手順 18、 3の画像 2 HP ProBook 450 G4 Speaker Replacement: 手順 18、 3の画像 3
    • Use the Phillips #0 Screwdriver to remove the two 3.5mm screws connecting the speakers to the top case of the laptop.
  19. HP ProBook 450 G4 Speaker Replacement: 手順 19、 2の画像 1 HP ProBook 450 G4 Speaker Replacement: 手順 19、 2の画像 2
    • Insert the spudger underneath each speaker to detach them from the top case of the laptop.
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Sebastian Dow
メンバー登録日: 01/23/20
1,043 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team S1-G3, White Winter 2020 Cal Poly, Team S1-G3, White Winter 2020人のメンバー
CPSU-WHITE-W20S1G3
4 メンバー
18のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 12
過去 30 日: 27
今までの合計 843
